Sun, Feb 16, 7:45 PM CST
Subject: OctaneRender for Poser
face_off ( ) posted Tue, 12 March 2013 at 5:56 PM
I have just posted the new build of the plugin - compiled against Octane 1.11, so it contains the new panoramic cameras, volumetic fog, additional post-processing effects, and a bunch of minor tweaks.  Details at render.otoy.com.
Paul
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
face_off ( ) posted Fri, 26 April 2013 at 6:06 AM
I have just posted the new build of the plugin - compiled against Octane 1.13.  The nicest enhancement is that Octane is now very friendly to people using just a single card of rendering and as the Windows dispaly adapter.   The other neat thing about this release is the ability to modify the diameter of the sun (to soften shadows) and change the sky color!
Paul
Blog
Facebook
face_off ( ) posted Wed, 22 May 2013 at 7:44 PM
I have just posted a very big update to the OctaneRender for Poser plugin (now at version 1.14a).  Pls see http://render.otoy.com/forum/viewtopic.php?f=45&t=32641 for details.
I have also posted an experimental Mac build of the plugin.
Paul
Blog
Facebook
RGUS ( ) posted Thu, 23 May 2013 at 2:11 AM
Thanks Paul... and what a dream... so many new features... and I swear it runs faster... or... maybe I just love the plugin so much!
face_off ( ) posted Fri, 28 June 2013 at 6:18 PM · edited Fri, 28 June 2013 at 6:18 PM
Attached Link: http://youtu.be/og65VflB4-Y
Check out the new video from Otoy showing the features of the latest OctaneRender build.
The Mac version of the plugin is also done and can be downloaded from the Otoy forums.
Paul
Blog
Facebook
face_off ( ) posted Thu, 04 July 2013 at 4:19 AM
OctaneRender for Poser comes out of beta on the 15th July, so if you want the cheaper beta pricing, get in before then.  The Mac version is also now fully supported.
Octane 1.20 was release last week, and the Poser plugin will be updated to 1.20 in the next few days.
Paul
Blog
Facebook
RGUS ( ) posted Thu, 04 July 2013 at 10:26 AM
Great news Paul... I think I've even forgotten how to setup a firefly render now.
Kalypso ( ) posted Sat, 20 July 2013 at 9:31 AM
Site Admin
Well I just missed the beta pricing by a couple of days.   So, before I take the plunge and invest in the pricier version I decided to try the demo.   Now, on the purchase page it clearly states that the poser plugin needs the stand alone version as well (unfortunately driving up the price even more)  but on the download page for the poser plugin demo no such mention is made.   Should I download the stand alone demo and the poser plugin demo?  Or just the poser plugin demo?
wimvdb ( ) posted Sat, 20 July 2013 at 9:40 AM
You need the license for the standalone. You do not need to download and install the standalone if you are going to use the plugin
So in your case demo licenses for both
Kalypso ( ) posted Sat, 20 July 2013 at 12:26 PM
Site Admin
Ok I downloaded both demos, the standalone and poser plugin.   Then I start Poser and I get this message:  " TypeError: attribute of type 'bool' is not callable"
Under the Render menu I do not have the Octane Render option.   Octane Render for Poser does show up in the Scripts menu but from reading the manual I'm supposed to have the Octane Render option in the Render menu as well as that's where everything is controlled.  The manual itself seems to be written for an earlier iteration of the plugin demo as it mentions a zip and placing a .dat file in the poser runtime whereas I downloaded an .exe file which installed itself after I pointed it to the PP2012 runtime.    Everything installs in the Python library.  Do I have to manually move any files somewhere else?
wimvdb ( ) posted Sat, 20 July 2013 at 12:36 PM · edited Sat, 20 July 2013 at 12:38 PM
Quote - Ok I downloaded both demos, the standalone and poser plugin.   Then I start Poser and I get this message:  " TypeError: attribute of type 'bool' is not callable"
The installer has replaced the zip file installation. That should work without you doing anything.
You have not mentioned it - but do you have the latest SR installed for PP2012?
the plugin uses the addon feature of Poser which was introduced in SR2 or SR3 (not sure which one).
And - do you have other plugins installed? Or are you using any other python scripts which are started automatically? Some cause a conflict with addons.
There is a file called octaneplugin.log which will tell you if the plugin has correctly loaded or where it has failed. It is located in Users/Appdata/Local/Temp/Poser Pro/10/
See at what point the plugin loading aborts
Kalypso ( ) posted Sat, 20 July 2013 at 1:10 PM
Site Admin
I'm on Win XP 32-bit Service pack 3.  My graphics card is a GeForce 9800GTX/9800GTX+ with the latest drivers.   I'm running Poser Pro 2012 with service release 3.1 and even DSON works without a hitch so I know I'm on the latest SR.   Could DSON be causing the problem?  I don't know if any python scripts start automatically.  How can I find that out?
And here's what the octaneplugin.log says.   Towards the end is says Octane library failed to load but I don't know enough to understand at what point that happens and for what reason:
DEBUG:root:addon:init
DEBUG:root:Python Version : 2.7
DEBUG:root:Platform : win32
DEBUG:root:OS Architecture : 32bit
DEBUG:root:Poser Version : 9.0
DEBUG:root:Poser App Version : 9.0.3 .23027
DEBUG:root:Plugin Version : 1.16a6 *** DEMO ***
DEBUG:root:OctanePlugin.py = C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for PoserOctaneWrapper.pyc
DEBUG:root:OctaneDefaults.py = C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for PoserOctaneDefaults.py
DEBUG:root:Loading Octane library C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for Poser32 DemoPoserOctane32_Demo.dll
DEBUG:root:Paths
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for Poser32 Demo
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonPoserScripts
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012python27.zip
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonDLLs
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonlib
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonlibplat-win
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonliblib-tk
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonlibsite-packages
DEBUG:root:C:Program FilesSmith MicroPoser Pro 2012RuntimePythonlibsite-packageswx-2.9.1-msw
DEBUG:root:octane.dll: date/time = Sun May 26 09:56:14 2013, filesize = 8057344
DEBUG:root:PoserOctane.dll: date/time = Sun May 26 10:26:10 2013, filesize = 93184
DEBUG:root:octane.dat: date/time = Sun May 26 09:56:12 2013, filesize = 39076542
DEBUG:root:Current Directory = C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for Poser32 Demo
DEBUG:root:Octane library failed to load
DEBUG:root:addon:load
DEBUG:root:init:objectsAdded
DEBUG:root:init:sceneDeleted
DEBUG:root:addon:unload
wimvdb ( ) posted Sat, 20 July 2013 at 1:20 PM
 Ok, I think I know what the problem is.
This installer makes the mistake of thinking that all installs of PP2012 are 64bit, so it installed the 64 bit version of the plugin. But you are running the 32bit bit version of Poser (since you are running om XP32). So it tries to load the wrong version.
The licensed version has already been updated and give you the choice of downloadint the 32bit or 64 bit version of the plugin. It looks like the demo version has not been updated yet.
From the log file you can see that "octane library failed to load" - it is trying the wrong version for you version of Poser (and OS)
I will email FaceOff about this and direct him to this thread as well
With regards to Reality - yes you can have both installed as addons if you have the latest releases of both reality and octane
Autoloading scripts - not sure how they do that. You can see it if tools are installed when you start up (widgets, python menus, etc). In some cases they can prevent the initialization of a plugin - which has not happened in your case
Kalypso ( ) posted Sat, 20 July 2013 at 1:34 PM
Site Admin
Great, thanks a lot for the help!   I hope face_off can update the plugin demo as I'd really prefer to try it before buying.
wimvdb ( ) posted Sat, 20 July 2013 at 1:50 PM
I sent him an email. So I think he will respond as soon as he is able to
face_off ( ) posted Sat, 20 July 2013 at 5:17 PM
***Great, thanks a lot for the help!   I hope face_off can update the plugin demo as I'd really prefer to try it before buying. ***
As Wim said, an issue was identified with the 32 bit installer which is now fixed with the commercial release but I haven't updated the demo version yet.  Could I ask you to email me at paul at physicalc-software dot com, and I will send you a link to the new installer (prior to posting it on the Otoy site).
Thanks
Paul
Blog
Facebook
face_off ( ) posted Thu, 25 July 2013 at 7:47 PM
Attached Link: http://www.ustream.tv/recorded/36313045
Jules Urbach's presentation on Octane at Siggraph 2013.  Absolutely stuff!  Imagine running Poser on the cloud via a Firefox broswer on your phone - and rendering in Octane in a few seconds.
Blog
Facebook
face_off ( ) posted Mon, 10 February 2014 at 4:21 PM
Attached Link: http://youtu.be/RO_nkBefnJo
Thought this was a pretty impressive video by "Chopper" using Octane.  HD resolution, rendered at 30 seconds per frame (unsure on hardware - but likely to be multiple cards at that render speed).
Paul
Blog
Facebook
ironsoul ( ) posted Tue, 11 February 2014 at 2:50 AM
So 2-3 hours for entire animation? Not bad at all :)
Sorry if this has been ask before in this thread but if we're talking about dual cards the budget must be comparible with that of a KeysShot license, do you know how the two products compare (not that I'm considering that kind of budget but interested in the comparision)
face_off ( ) posted Tue, 11 February 2014 at 4:07 AM · edited Tue, 11 February 2014 at 4:08 AM
My understanding is that Keyshot doesn't have an integrated plugin or Poser - so there is no way to render an animation through that renderer - so it's not a viable option for rendering animations.
My best guess is the hardware for this was in the $500-1000 range.  But at 30 secs per frame, you would expect that.
Paul
Blog
Facebook
dsyee75 ( ) posted Wed, 12 February 2014 at 1:52 PM
Quote - Thought this was a pretty impressive video by "Chopper" using Octane.  HD resolution, rendered at 30 seconds per frame (unsure on hardware - but likely to be multiple cards at that render speed).
Paul
30 seconds per frame...I realize there aren't a lot of polygons in the scene, but that's still freaking unbelievable.  Do you know what his typical samples/pixel was?  And what hardware exactly?
wimvdb ( ) posted Wed, 12 February 2014 at 2:26 PM · edited Wed, 12 February 2014 at 2:28 PM
Quote - > Quote - Thought this was a pretty impressive video by "Chopper" using Octane.  HD resolution, rendered at 30 seconds per frame (unsure on hardware - but likely to be multiple cards at that render speed).
Paul
Not too long ago he mentioned het had 2xGTX780i and 1xGTX680i in the machine.
He has not mentioned samples/pixels. But that varies depending on the materials in the scene itself. Some scenes are perfectly fine with 500 samples, others need 8000.
dsyee75 ( ) posted Wed, 12 February 2014 at 10:51 PM
Quote - > Quote - > Quote - Thought this was a pretty impressive video by "Chopper" using Octane.  HD resolution, rendered at 30 seconds per frame (unsure on hardware - but likely to be multiple cards at that render speed).
Paul
Well, that explains it. :)
It's clearly a Victoria 4 model, looks like it has SSS and possibly falloff map applied to the skin.  On my PC, 30 seconds would probably give me 60-100 samples/pixel at that resolution, so I was wondering what he got...I'm guessing more than 60-100 ;)
wimvdb ( ) posted Thu, 13 February 2014 at 6:56 AM
He is using a variation of the REDSPEC shaders which is a sophisticated SSS shader.
The samples/pixel comparision is a very tricky one. Let me give you an example.
If you take a V4 with a complex shader (like v4) I get around 400-500 samples/pixel in a scene like that (720p, no closeup), 30 seconds, but in a video I probably need less.
If I were to put her in a glass bottle it would drop down to 200-300 samples/seconds and I would need more samples and I would probably need around 500 if I turn on hotpixel removal so that would make it a minute
If I would use PMC instead of path tracing I would get around 70 samples/second but I might need only 100 to get a good result with the glass bottle (with some caustic blur added)
If I were doing a closeup, I will get lower number of samples, but I could get by with a lower number.
What I found is that the number of samples needed really depends on the amount of available light (more is faster) and how much light needs to travel through specular materials. A light in a glass bulb will need a lot more samples as one without the bulb.
These estimated times are for my machine which has a dual titan for gpu rendering, so pretty fast as well. With a single 780 double the amount of time needed.
dsyee75 ( ) posted Thu, 13 February 2014 at 8:12 AM
Interesting and helpful, thanks!
face_off ( ) posted Thu, 06 March 2014 at 4:31 PM
Attached Link: http://render.otoy.com/forum/viewtopic.php?f=7&t=38655
Pretty big news announced today.....the OctaneRender engine is now free for students.  See the link above for details.
Paul
Blog
Facebook
dsyee75 ( ) posted Thu, 06 March 2014 at 5:22 PM
Quote - Pretty big news announced today.....the OctaneRender engine is now free for students.  See the link above for details.
Paul
Very cool!  Although, as a graduate student, I wish I'd waited for this instead of blowing $$$ on the standalone a few months ago :).  (Assuming the student license would also "count" for the Poser plugin)
face_off ( ) posted Thu, 06 March 2014 at 5:44 PM
No - students get Standalone at no cost, but still pay or the plugin.
Paul
Blog
Facebook
dsyee75 ( ) posted Thu, 06 March 2014 at 5:58 PM
I meant, since the plugin requires a standalone license, does the student version "count" as a standalone license for that purpose?  Irrelevant for me now, but maybe for future reference...
face_off ( ) posted Thu, 06 March 2014 at 6:15 PM
Yes - if you purchase the plug, you don't need to purchase Standalone too - so a big cost reduction.
Blog
Facebook
face_off ( ) posted Tue, 25 March 2014 at 7:38 PM
Attached Link: http://www.bizjournals.com/sanfrancisco/prnewswire/press_releases/California/2014/03/25/NY90317
OctaneRender 2 features have been announced.  Significant for Poser users is support for displacement mapping and dynamic hair, plus the combined Daylight & HDR lighting mode.
Paul
Blog
Facebook
face_off ( ) posted Tue, 25 March 2014 at 7:48 PM
Attached Link: http://render.otoy.com/newsblog/
More detailed info at the link above.
Paul
Blog
Facebook
aRtBee ( ) posted Wed, 26 March 2014 at 2:51 AM
Any dates yet? Including a renewed Poser plugin I presume? Displacement and hair support are very very welcome.
Announcements are for "2nd half of 2014" which sounds like XMas to me.
face_off ( ) posted Wed, 26 March 2014 at 3:35 AM · edited Wed, 26 March 2014 at 3:35 AM
Abstrax indicated a first beta release in April in the forums.  I am playing with the Poser plugin 2.0 at the moment :-)
Blog
Facebook
colorcurvature ( ) posted Wed, 26 March 2014 at 9:04 AM
just found this thread. does poser2octane work with EZSkin? Or is there an EZSkin edition to make nice octane shaders?
aRtBee ( ) posted Wed, 26 March 2014 at 9:24 AM
my own findings, in a nutshell: most surface properties which can be managed via the Simple interface are supported, about every property which cannot be managed that way and needs the Advanced interface explicitely, is hardly supported. The only node that is supported well is image_map.
This holds for all external renderers, whether they are Vue, Reality/LuxRender or Octane, or other ones. In general, geometries transfer well but cameras lights and materials have to be reconsidered, and preferrably redone and optimized to get real quality out. External renderers are not "just another firefly".
just my opinion.
wimvdb ( ) posted Wed, 26 March 2014 at 10:33 AM
There are skin shaders available with similar features as ezskin: You load your poser materials as normal. The plugin makes a simple conversion (diffuse, specular, bump and transparency maps). Then you apply the shader in the plugin with "import all materials for this figure/while retaining texture maps) and you will have your skin with the SSS and other settings. So pretty much what EZSkin does.
Some shaders cannot be translated since there is no equivalend function available or where the implementation does not require it or needs a complete different approach (like glass and water). There are plenty of materials in the LiveDB database which can replace those shaders.
-Timberwolf- ( ) posted Wed, 26 March 2014 at 3:58 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=2521624
Oh man, Octane render for Poser is such a blessing. May I show off here ? ;)
face_off ( ) posted Mon, 09 June 2014 at 7:22 PM
Attached Link: http://render.otoy.com/forum/viewtopic.php?f=7&t=40378
OctaneRender 2 has been released!  Existing users can upgrade to Octane Standalone 2.0 and get a free upgrade of the Poser plugin for a limited time.
In Summary, Octane 2 has:
  • Displacement Mapping
  • Motion Blur
  • Dynamic Hair Support
  • Subdivision Surfaces
  • Render Region (this is awesome!)
  • Network Rendering
Paul
Blog
Facebook
aRtBee ( ) posted Tue, 10 June 2014 at 5:22 AM
got it. Paul, thanks again for all the effort !
-Timberwolf- ( ) posted Tue, 10 June 2014 at 6:01 AM
How long will the upgrade for Poser be free? My internet access for my 3d Pc is down at the moment.
face_off ( ) posted Tue, 10 June 2014 at 6:09 AM
I'm not sure - but my best guess is a few weeks.
Paul
Blog
Facebook
ErickL88 ( ) posted Tue, 10 June 2014 at 11:12 AM · edited Tue, 10 June 2014 at 11:12 AM
This is great.
Thanks for the heads up and effort, Paul :D
ghonma ( ) posted Tue, 10 June 2014 at 11:37 AM
Anyone considering upgrading should take a look at this thread first:
http://render.otoy.com/forum/viewtopic.php?f=27&t=40385
aRtBee ( ) posted Tue, 10 June 2014 at 11:54 AM
ough. But v1.5 is much faster than v1.2 so we can bear some drawback. Otherwise I have to overclock my things even more, or we have to figure out how we can have both versions in parallel. I do want displacements and dynamic hair though...
wimvdb ( ) posted Tue, 10 June 2014 at 1:04 PM
The 2.0 render clears up quicker as the 1.5 render so you may not need as many samples.
I never noticed a serious slow down with 2.0, but I have not rendered the same scenes in both 1.5 and 2.0. So it is difficult to tell how much slower it is. The new features may have an influence on the render speed as well .
I am happy with 2.0. Features like improved IES lights, simultaneous Daylight with HDRI maps, motion blur  and displacement are well worth it for me.
TylerZambori ( ) posted Tue, 10 June 2014 at 2:03 PM
How do you all like Otoy's customer service?
wimvdb ( ) posted Tue, 10 June 2014 at 2:08 PM
I contacted Otoy twice and their response was quick and fixed the problems and questions I had.
Paul (FaceOff - developer of the Poser plugin) - has always been very responsive and quick to fix problems - both on the Otoy forums and y email
That is my experience
DustRider ( ) posted Tue, 10 June 2014 at 9:33 PM
Quote - Anyone considering upgrading should take a look at this thread first:
I upgraded to 2.0, I think the reports of it being slower may just be from people looking at Ms/sec, not at image resolution speed.
I've done some very unscientific testing, and I'm getting anywhere from 10-21% slow down in Ms/sec, but the images are clearing up much faster. Even with the loss in speed, my renders are reaching the stopping point for quality in about 1/3 to 3/4 the time required with 1.5. But I haven't tried a lot of complex SSS shaders, I have been using direct light, path tracing, and PMC, al with similar results.
Of course, your mileage may vary depending on scene complexity and the gpu/#of GPU involved. My simple system pales in comparison to the people who are reporting major slow downs - mine is a laptop running a Geforce 670M (Fermi). Maybe there is a performance hit on multi-gpu systems that I'm not experiencing, but for me, I'm quite happy with the performance of 2.0 - slower, but faster.
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
face_off ( ) posted Tue, 10 June 2014 at 10:00 PM
There are also a lot of changes internal to the plugin which have changed the structure of how the Octane nodes are connected.  So not much point comparing speeds.  Most people have reported that images are becoming noise-free with fewing samples (and less time) though (due to the changes in how emitters are managed). And if speed is an issue, cloud rendering is just around the corner.
There are other positive things to come from the changes above - for example when you have "Live Update" on, the plugin is not recreating mesh nodes and reloading the geometry any more - it's only updating the vertex and normal positions - so that is way faster.  Similarly when rendering animations - only the vertex and normal positions are updated each frame - not the entire mesh.  Also, you can load the level 0 subd of the Poser mesh now and subd inside Octane, with initial tests on Andy showing a 2-3 x times scene load time reduction.  The changes also mean you can Network Render, and when you change part of your Octane scene (the camera position for example), only the camera coord change gets sent to the slave PC, so it is updated almost instantly in a lot of cases.  And finally, the node structure changes mean that you can export animations to Alembic format (wrapped inside the OCS/ORBX Octane format) - so scene assets (figure and their animations) can be exports and mix/matched inside Octane Standalone.  Whilst this won't mean a lot to the hobbist, it is critical for studio who use this workflow.
Paul
Blog
Facebook
