Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Isn't that DAZ Studio screen shot? This is Poser forum. Can you show it as it is in Poser, deformed and normal?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Quote - Isn't that DAZ Studio screen shot? This is Poser forum. Can you show it as it is in Poser, deformed and normal?
I could if my version of Poser (Poser Debut) worked on my current system; I'm a victim of the Windows IE update debacle, so until and unless Smith Micro comes up with a patch for that, DS is my default 3D modeling tool.
As it is, the Fantasy Wrap came out at a time when Poser 4 was the standard; one could open up a CR2 or a PP2, etc. in a text editor and modifiy it by hand, which is why I brought this question to the Poser forum.
If the moderators believe this thread would be more appropriate to the DS forum, I do not object to it being moved.
You might want to check out the updates for Debut.
http://poser.smithmicro.com/debut-updates.html
The last update says it works with Windows 8.0 and 8.1 and came out after the problems people were having with IE 11.
Quote - You might want to check out the updates for Debut.
Ah! Thanks for that much, anyway. I'll look into it. :-)
Though, if anybody has looked "under the hood" of the Fantasy Wrap, I'd appreciate any help.
I'll just cross-post this to the DS forum and see what I can find there.
For anybody still having Poser 8 problems. the solution is pretty simple to get IE 11 off their "puters". Go to Control panel (program features-turn windows features on or off) and tell windows not to use IE11 then uninstall IE 11 (which is listed as an Windows upgrade). Then either use the MS "block IE11" program to prevent the installation or just forbid Windows from automatically installing upgrades without your approval (ie: IE 11). IE 11 is listed as an optional ugrade (go figure). Restart and Poser 8 is back in ful.
I suspect it may be a parenting issue (I ran into a similar problem with the Cowboy Boot for Michael 2 a few years back) and I’m going through the CR2 file line by line, to see where it differs from “FANTASY WRAP 2 FT”.
Given how old this outfit is, I was hoping that somebody else might have run into this problem and solved it before me.
Any help is greatly appreciated.
The attached image shows how the “FANTASY WRAP 2 BK” is deforming; the figure’s abdomen and hip have been turned invisible for clarity.
