Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Good idea. I removed all the other sub folders in Poser. Loaded the prop back into the picture, same thing thing happened. Even if there are no other figures/props.
I will do some more digging, I think both of your ideas were good ones.
I just noticed, in the materials room, all other parts of the skirt load but the handles & cloth. I will need to figure out what the cloth file is called so I can track down the other file that shares the same name.
To clear my confusion is the skirt a conforming figure ?
if it is are there any defects visible , or is it just loading to the wrong place ?
what happens when you load the figure, load the skirt and then do the conform ?
the skirt should import to the right position on the figure even without using a cr2.
you can look at the conformer and check that all the body parts are correct (match the figure)
If it is a prop then it will not conform but should be parented.
Quote - To clear my confusion is the skirt a conforming figure ?
Yes, it should conform to the figure. The above screen shot shows the skirt. On the right side you can see Posers library window with a picture of how the skirt should look. I think the texture map is missing from the cloth section on the skirt. Other items built into the skirt have textures to them, they just do not show up because the cloth texture part is not loading correctly. The skirt looks like it is missing the sides of the skirt.
The skirt ends up in the same area on the screen with or without the figure loaded.
Thank you all for you time.
when I use conforming clothing I load the figure, then th clothing and then use the menu option conform to0 as you have shown. Once that is done I pose the figure.
It certainly looks like you may have file placement problems.
Do you have Poser set for deep search in the configuration, or get any messages about missing files ?
There should be a file listing with the products. You should be able to check the files are in the right place by using the windows file manager.
All other props that came with the set load correctly. I have gone through the files downloaded in Poser Pro 2014 and the readme the vendor provided. All items have been installed in the correct folders. The vendor has even downloaded the files from the same zip and is not having an issue.
Problem, when loading the skirt, it conforms to the k4 face. There are no texture maps that load with the skirt. All the other props with the program load onto the k4 figure without issue.
Other then my bad spelling..lol..Does someone have an idea on what I can do to fix this issue?
Picture attached is a screen shot. Yes I did load multiple skirts, trying different things to get it to load correctly.
Computer windows 7. Poser Pro 2014.
Thank you
