Fri, Nov 22, 1:41 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Python Collada export?
Cage ( ) posted Thu, 03 April 2014 at 10:46 AM · edited Thu, 14 November 2024 at 3:32 AM
file_503274.txt
Does anyone know if Poser Python actually supports Collada export via the scene.ImExporter()?  I can't seem to get it to work, using the known techniques for the other export formats.  I'm beginning to suspect that this is another broken feature, in spite of all those special COLLADA Codes in the manual, but I don't know for certain.
The attached is my testing code....
semidieu ( ) posted Thu, 03 April 2014 at 2:27 PM
I can't make it work too :(
Tested with basic code and seems to not be working...
Cage ( ) posted Thu, 03 April 2014 at 2:38 PM
Okay.  Thank you for trying it.  :biggrin:  I tend to seek verification, in cases like this, because... you know.  Cage tends to make the silly mistakes and then, somehow, fail to see where those mistakes lie.  It's a problem.
So... I guess I have to go talk to Customer Support again, with another bug report.  :scared:
