Mon, Nov 25, 1:57 AM CST
Subject: Question about V3 and v 4 figures
friscolives ( ) posted Mon, 07 April 2014 at 2:02 AM · edited Mon, 25 November 2024 at 1:37 AM
I downloaded a few figures, v3 and v4 for instance, and I'm confused as to the difference on some of them. I see terms like Dev example and dev foundation, Sae, v3 to v2, and others. Can anyone explain the difference? Is there one in particular I should be using?
PhilC ( ) posted Mon, 07 April 2014 at 2:25 AM
It is a bit like motor vehicles, there was nothing wrong with the '13 but now the '14 is out the '13 is considered old hat. Much will depend on whether or not you must follow the crowd and be seen driving the "latest and greatest" or if you prefer to be a creative individualist.
Then again some folks are happy to just insert the key, click once and drive off whilst others take artistic customisation to the limit. Current drivers sport V6 but secretly keep a V4 in their garage.
You are in the driving seat, it is an open road not a one way street.
friscolives ( ) posted Mon, 07 April 2014 at 4:56 AM
I can understand the difference between Vickie 3 and 4, but was more curious on what is the difference between the "Dev", or SAE or some of the various forms of the same figure. I open the Vickie 4.2 version and I have Vicke 4.2 Dev, also Vickie 4.2 SAE etc. I think there are even more, and its confusing as to which one would I use.
shvrdavid ( ) posted Mon, 07 April 2014 at 5:43 AM
A Dev file stands for Developer. It is a stripped down version of a character used to rig things like clothing.
SAE usually means it has extra injection channels in the characterc cr2 file, but I am not sure if that is the case on V4.
The one you want to use is plain old Victoria 4.2.
EClark1894 ( ) posted Mon, 07 April 2014 at 5:48 AM
Actually, I'm not sure what the "SAE" version is all about, but V$ had about three or four different versions out at one time, including a lo rez version. V4 is the original, V4.1 was an update and V4.2 was I believe the last update to the figure from DAZ. The DEV rig is a Poser Development  Rig for people who wish to make clothing and props for V4 to wear and use.. That's it in a basic nut shell.
WandW ( ) posted Mon, 07 April 2014 at 8:07 AM
I recall V3 SAE was an update released as part of a Special Anniversary Edition bundle.
If you have Poser 9 or higher there are weightmapped versions of both, which have immproved bending...
V3WM
http://basicwiz.com/VICTORIA-3WEIGHTMAPPED.zip
V4WM and the Outfitter clothing weightmap transfer utility..
http://www.runtimedna.com/Poser-Place/
Taren421 ( ) posted Mon, 07 April 2014 at 12:59 PM
The V3 to V2 version of Victoria3 allows her to wear clothing & to use poses made for V1-V2, and to use the texture maps designed for those figures, but has the head morphs of V3.
V4 to V3 version does the same but for V4-V3.
Poser Pro 2012 SR3 on Win10 x64 w/Reality.
Poser Display Units = inches.
