if you have lightwave you dont need bryce you can export bryce terrains out as lightwave scene files with the textures intact its a nice shortcut to avoid modeling a mountain range but the render in LW is far superior to bryce
Well, I exported a Bryce 5 terrain to LW 6.5b and it was OK except that the texture map was sort of dull even at 1024 as a BMP. I decided to mix this with my own mixes for terrains and it comes out really nice. I notice that Bryce 5 exports terrains in a better way than Vue 4 but as Vue it doesn't export DEM's 100% intact. Cheers!
Attached Link: http://www.lightwave3d.com/tutorials/surface/texturing/texturing_landscape.html
Here is one that shows the basics of displacement mapping to make landscapes. For the bryce end you need to make your landscape with the terrain editor. Make a altitude render from the top, if you want you can also make the texture by rendering a color map from the top. Then use those renders as the lightwave displacement map. GriggsThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi everyone, I plane to buy Bryce5 but as I'm not very sure that it will work well for what I expect from it, I would like to have your opinions. Is it REALLY possible to export a scene of Bryce5 into Lightwave (5.6 to 7), WITHOUT loosing informations ? Is that stuff really that good, easy to use and fast rendering ? Thanks by advance, Jean-Paul.
