Do you mean so that only the last area render you did is the only one visible?
If so, I don't think there's a specific feature for it but I suppose you could always store the camera position, rotate to render under the floor so that you get a black render, then use the stored camera position to get your original view back and render a different area.
That said, I don't really understand why you want to do what you're asking so I'm probably misunderstanding what you're getting at.
You are getting what I want to do!
It is very cool that one can do an area render over your previous render, but the area render leaves a whitish mark on the bottom and right hand side.
I just noticed that there is a "render over black" option in the render settings. I don't know if that would work for area renders but I am going to try it now.
Poser 11 Pro, Windows 10
I used to use area renders all the time. When a scene would crash Poser 8 because it ran out of memory, I'd turn off troubling parts (like transparencies in hair), render the scene, and then just render the part I needed to add.
I still sometimes do it. If I look closely at a render and find a tiny little annoying thing I missed, like a finger digging into some skin or whatever, I just repose and then rerender the hand and layer it over the bigger render in post.
Great for test renders when you only changed a small area, too.
It's an excellent tool.
I am faced with having to render parts of an image with area renders and late superimpose them on my main render.
How do I clear the render window to remove the leftovers from previous render attempts so that I can export a clean area render?
This may be a very ignorant question, I apologise. I just don't know how to do this.
