Mon, Dec 23, 7:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: HELP!!!!!!
shante ( ) posted Thu, 01 May 2014 at 1:53 PM · edited Mon, 23 December 2024 at 1:57 AM
I messed up really bad and can't figure out how to fix it.
I was working on a render set-up and clicked the camera controls to reposition where I could reach the better. I moved the cursor with the click hold function on the mouse and accidentlly let it go behind the stsge image. So I moved the stage image to reposition the tool and found the tool grab bar way up along the tabs menue on the screen (see attachment)
I tried for an hour trying to move the darm tool menue for the camera controls lower to no avail.
I tried resetting the launceh Poser preferences hoping the tool bar would go to default state by clicking to relaunce to factory settings but also no work.
Has anyone ever had this problem and if so how do I fix it!
I can't believe there are no tool functions in Poser (that I can find) that would reset the desktop to a default positioning of the tools. I can't believe there was no paramater controls seto up that would NOT allow the tools grab bars to go up that far. Trying to capture the grab bar of the camera controls set clicks the set-up tab behind it.
HELP!!!!!!!
willyb53 ( ) posted Thu, 01 May 2014 at 1:58 PM
No real tool to fix it easily, but if you set a UI dot when you first set up, you can pull it back to where you had it.  One way to fix is set preferences to factory state and rebuild your UI.  then save it and a UI dot
Bill
shante ( ) posted Thu, 01 May 2014 at 5:37 PM
Quote - No real tool to fix it easily, but if you set a UI dot when you first set up, you can pull it back to where you had it.  One way to fix is set preferences to factory state and rebuild your UI.  then save it and a UI dot
Bill
Thanks for your reply WillyB
I got it figured out. I reset to remove to save to last saved setting opting for factory and the tool dropped into default, rebuilt the work space the way I like it and reset it again to preffered and saved the file. When I relaunched the file i was working on it all went back Las Way Saved settings and BINGO!
I got frustratd and my mind shut down and came here for miracles little remembering my own mind is supposed to be a miracle in itself.....well.....when I works right!  LOL
