Mon, Jan 20, 12:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Thought I'd share this
Teyon ( ) posted Thu, 15 May 2014 at 11:15 AM · edited Sun, 19 January 2025 at 11:48 PM
Attached Link: Denim Texture.
It's a denim-like texture I created entirely in Photoshop. No photos used. Hopefully you can use it. It's a zip with a 2048x2048 PNG file of the diffuse texture.  I've included a quick pic to show how it applied to a pair of shorts I'm making. Keep in mind the stitching and wrinkle detail is from a normal map that's specific to the shorts and so, not part of the texture. Try it on your own clothing.
ThunderStone ( ) posted Thu, 15 May 2014 at 11:42 AM
Online Now!
Thank you. It's very hard to get good looking denim texture. This one looks very well made
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Teyon ( ) posted Thu, 15 May 2014 at 12:29 PM
Thanks. Glad you like it.
NanetteTredoux ( ) posted Thu, 15 May 2014 at 1:05 PM
The texture is nice, but the way you used it is even nicer.
Poser 11 Pro, Windows 10
Teyon ( ) posted Thu, 15 May 2014 at 1:51 PM
Thanks. :)
Alisa ( ) posted Thu, 15 May 2014 at 2:01 PM · edited Thu, 15 May 2014 at 2:03 PM
Lovely - thanks!
And the pants look great, too!
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
patslash ( ) posted Thu, 15 May 2014 at 2:58 PM
Very good! I am impressed!
EClark1894 ( ) posted Thu, 15 May 2014 at 3:42 PM
I've been holding onto a pair of jeans i made for Roxie for months because I didn't have a decent jeans texture for them. Gonna try it out later.
Teyon ( ) posted Thu, 15 May 2014 at 3:48 PM
Sweet. Glad to be of help gang. :)
Teyon ( ) posted Thu, 15 May 2014 at 3:57 PM · edited Thu, 15 May 2014 at 3:59 PM
In the spirit of sharing: I find it works best if you lay out your clothing to be as straight as possible and along the natural seams of the item in question.
Pugster56 ( ) posted Thu, 15 May 2014 at 5:23 PM
Thanks! Will use it!!
Teyon ( ) posted Thu, 15 May 2014 at 7:58 PM
Please do. :)
Coleman ( ) posted Thu, 15 May 2014 at 11:59 PM
Great texture! Thanks a lot, Teyon !
Teyon ( ) posted Sat, 17 May 2014 at 4:51 AM
colorcurvature ( ) posted Sat, 17 May 2014 at 4:55 AM
Trying to make a cap out of this fine denim ;) I still heavily suck at modelling but its getting better slowly slowly. Also, what might the best render settings be? I found that Poser render results seem to blur at unexpected places, and there seem to be rectangular artefacts. Maybe that is because of the detail level of this texture? Modelling wise, I wonder what is your technique to guide stitches along the mesh, without stretch, like the 4 towards the top center and around the bottom of my cap? Its made with displacement. I do not find my result too bad but it took long to do; but my workflow is a bit odd; I have made a script for blender to straighten UVs for a faceloop without stretching them. Then I use these specialized UVs to clone a texture onto the "productive" UV map which might have a completely different layout. It takes many clicks for an operation that "feels" it should rather be "atomic". :(
colorcurvature ( ) posted Sat, 17 May 2014 at 4:57 AM
Teyon ( ) posted Sat, 17 May 2014 at 5:53 AM · edited Sat, 17 May 2014 at 5:54 AM
Attached Link: Selwy's cloth brush tutorial page
Hey. Well, here's a shot of my render settings and the shorts with just a normal map and not the diffuse texture I posted. You can see that a lot of the work is done via the normal map and the diffuse just pushes it a bit more.  That said, while the mesh itself is pretty good there's some minor distortion in the UV's along the front flap area, which is why you get  the sudden size difference in texture. Is that the artefacts you're speaking of?
The texture isn't tileable by default. That'd be something you'd have to setup manually. It was designed to fit my need, so all I had to do was use it as is, not pattern fill it or anything. I just placed it on top of my 2048x2048 template for my shorts. So if you used it like a tileable pattern, then yeah, you're going to see rectangular shapes where the pattern starts and stops. I guess a tileable pattern would be of more use, I hadn't considered that. Sorry. :-(
Modeling wise, I try my best to keep the polygons on the mesh as even spaced as possible (note that this isn't always possible to do in detail areas).  To actually create  the shorts I used masking in ZBrush to extract out the base form. Then I Sculpted out the idea of the shorts, using Lazy Mouse and ClayTubes to roughly define the seams. I then took that into Topogun to create the final topology. There I was able to draw a new topology directly on top of the old one. This made it easier to plan where to put detail and with the Relax brush in Topogun, I was able to smooth out the spacing of the polys a little.  Then I went into Silo to do an extrusion on the leg and waist openings, so that there appears to be some thickness to the shorts. It was here that I created the belt loops also by copying sections of the mesh, applying a Shell command on them and then bridging the sections back onto the mesh.  I also extruded a bit of depth for the pockets.
Then I went into Headus' UVLayout program and UVMapped the mesh based on the seam guides I made. In hindsight, I probably should have done a few more cuts but eh....whatever. I think it still works.
Once that was done, I went back into ZBrush with the new topology. I subdivided about 3 times to have enough polygons to start painting out the wrinkles I wanted. Using Polypaint only (meaning ZAdd/ZSubtract were turned off), I painted out where I wanted wrinkles.  White for peaks and Black for valleys and used the smooth tool (again, with ZAdd and ZSubtract off) to blend between them a little bit.   AT this point I could have tried using Mask by Color to help make the wrinkles but instead of doing that, I just went in Selwy's Cloth brushes (Fold 1 and Fold2 see link), the DamStandard brush set to ZAdd, and the Form Soft brush to get the wrinkles. I wanted the look of clothing that had been ironed in the past, so I added some lines in the front where someone may have pressed the shorts a bit.
To do the seams, at first I used Bryan Sylvia's Jean_Stitch brush  which worked pretty well but I had a hard time in some spots with it so I then did a combination of ClayTubes brush (ZAdd), DamStandard (both ZSubtract to define the crease and then ZAdd to lift the seam), and the Form Soft brush (used to add the dimples in the seam) wherever I was having a hard time using hte Jean_Stitch or for cleaning up a stroke.
For the final bit, I used Surface>Noise with my diffuse texture as the Alpha (see lower left corner of Surface>Noise for Alpha Load) set to UV instead of 3D....or was that 3D instead of UV? Anyway, it got the job done. I applied that to the mesh and I then generated a normal map.
Then in Poser I loaded the mesh, auto rigged it (still cleaning that up), applied the normal map plugged into the Gradient Bump Channel (set to Tangent Space) and loaded the texture in this thread as my diffuse with no additional editing done to it.
Later, I tried running it through Ddo, so I had to generate an Object Space (aka World Space) normal map as well as the Tangent Space map I had previously made. My goal was to use Ddo to dirty up the texture a bit (the Object Space map would help guide the direction of the dirt) but I ended up not using the result. Not because it wasn't good but because after talking to my girlfriend, I realized that maybe it'd be better to leave the texture clean.
So that was my process. I hope that helped in some way. It took me, all told, about two to three hours - most of that time was in Topogun, planning the detail areas. The actual sculpting was about an hour tops.
That's looking great by the way. Just thought I'd mention that. :D
Teyon ( ) posted Sat, 17 May 2014 at 6:00 AM
Here's a render of the same shorts without the normal map or the diffuse. This should better illustrate what's doing what.  FYI - the shorts have about 5,564 quad polygons.
vilters ( ) posted Sat, 17 May 2014 at 6:55 AM
(Click to enlarge)
Thanks Teyon, looking good on my free Mexican and Old gym outfits.
I connected a slight HSV adjustment in Diffuse, added some specular and bump both driven by the Denim map to get to this result with a single infinite light.
But, textures like these are very sensitive to moiré.
vilters ( ) posted Sat, 17 May 2014 at 7:00 AM · edited Sat, 17 May 2014 at 7:00 AM
(Click to enlarge)
here the material settings.
Teyon ( ) posted Sat, 17 May 2014 at 7:04 AM · edited Sat, 17 May 2014 at 7:06 AM
Cool and yes, they can fall victim to moire. The best way to avoid it is to make sure your uv's are as uniform as possible so that all polys gain the same amount of texture info (which is nearly impossible to do) and break up the pattern with some dirt or wear and tear. Though if you're making a product it may be wise to include a non-damaged version so that folks can add their own if/as needed. Anyway, glad to see folks using it and having fun with it. That was the whole point of me sharing. :)
vilters ( ) posted Sat, 17 May 2014 at 7:18 AM
(Click to enlarge)
Just fooling around with the HSV Value :-)
Nice texture to play with.
vilters ( ) posted Sat, 17 May 2014 at 7:27 AM
(Click to enlarge)
Just going bananas here, LOL.
Thanks Teyon.
EClark1894 ( ) posted Sat, 17 May 2014 at 9:22 AM
Denim shorts for Roxie with Teyon's Denim. Gotta admit though, I was gonna use Khaki, but the denim works. and I still have those other jeans for Roxie if I want.
vilters ( ) posted Sat, 17 May 2014 at 9:31 AM
You can still use Khaki in Diffuse_color
Use Teyons Denim map in Specular and Bump or Displacement in Poser. :-)
ThunderStone ( ) posted Sat, 17 May 2014 at 9:33 AM
Online Now!
Looks good!
EClark1894 ( ) posted Sat, 17 May 2014 at 7:12 PM · edited Sat, 17 May 2014 at 7:15 PM
Needs less bumps and some stitching... but I love the texture. Thanks Teyon.![](http://www.renderosity.com/mod/forumpro/art/emoticons/smile.gif)
DarthJ ( ) posted Sat, 17 May 2014 at 9:55 PM
Applied to dynamic dress and shoes.
Teyon ( ) posted Mon, 19 May 2014 at 3:56 AM
Great stuff gang. :)
