Sat, Jan 25, 4:11 PM CST
Subject: Genesis 2 to Vue 11 Infinite
arrow1 ( ) posted Thu, 10 July 2014 at 8:22 PM · edited Tue, 03 December 2024 at 4:09 AM
Has anyone had any success in importing a Genesis 2 figure from a Poser PZ3 into Vue 11 Infinite? I have tried many times and I get two figures.One the posed figure I want and the T shape default figure as well which I do not want in which I cannot separate as it becomes part of the original figure when imported into Vue! Any help or advice would be appreciated. I will also put this post in the Poser forum as well.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
thd777 ( ) posted Sun, 13 July 2014 at 12:50 PM
> Quote - Has anyone had any success in importing a Genesis 2 figure from a Poser PZ3 into Vue 11 Infinite? I have tried many times and I get two figures.One the posed figure I want and the T shape default figure as well which I do not want in which I cannot separate as it becomes part of the original figure when imported into Vue! Any help or advice would be appreciated. I will also put this post in the Poser forum as well.Cheers
Don't know if you have found your solution, but here is what I do using Vue 2014.5 with the October 2013 Poser SDK. If I recall correctly, this worked in Vue 11, too. As in your case with default settings, you get one mesh with the subD cage included (the T-pose figure). Change the Poser import settings as shown in the screenshot, make sure that "Group Figures as Single meshes" is unchecked. Upon import completion you will still see the extra mesh, but if you expand the figure you can now find the "SubD" sub-mesh and hide it from render or delete it. Hope this helps.
Ciao
TD
arrow1 ( ) posted Sun, 13 July 2014 at 6:11 PM
Many thanks. I will try your suggestion.The only difference is I have Vue 11 Infinite! Cheers
estherau ( ) posted Fri, 15 August 2014 at 8:40 AM
I've tried this in the past but there is always a UV problem with males.  the females take your V4 textures though.
MY ONLINE COMIC IS NOW LIVE
iborg64 ( ) posted Sun, 28 September 2014 at 3:58 PM
having had this problem my self once and taking weeks to find the solution . The answer is very very easy all you need to do once your figure is set up in poser how you want it is go to scripts-DSON support-Sub division -set sub division OFF. you may see your figure change and look a bit odd or clothes not fitting just move the camera and it will all jump back correctly.For some genesis clothes you will nees to do the same for each item shirt , trousers etc . if you see a duplicate of any item in vue on your genesis figure then do the same to that item .I usually keep poser open when I set up my figure then when i import in to vue if somethings duplicated .(last time was a pair of shoes on genesis never had that before)resave and vue will say its been changed by another program do you want to reimport? say yes and volia there it is!
This is also the way to fix mil horse 2 and the new daz dragon , with the horse you will need to do the mane and the tail as well as the horse.
Hope this is of some use to you
arrow1 ( ) posted Sun, 28 September 2014 at 6:48 PM
iborg64, Many thanks for your help.Cheers
