Tue, Nov 26, 1:43 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Multi Colors
kyraia ( ) posted Thu, 17 July 2014 at 8:16 AM · edited Tue, 19 November 2024 at 2:07 PM
On Youtube there is a nice tutorial which shows how to colorize many objects with different colors using only 1 shader ( see ). This is working very well as shown in the main part of the image attached (I simplified the shader as much as possible).
Next, I tried to apply this to the leafs of a tree, but this doesn't work. I think it is because all the leafs are just one object. So, is there a way to separate all the leafs so they can be adressed as many objects?
Thanks,
Kyraia
keppel ( ) posted Fri, 18 July 2014 at 12:05 AM
Firstly select your single leaf object that consists of all the trees leaves.
Go into edit mode and press "A" to select all the faces of all the leaves.
Press "P" which brings up the Separate selection box.
Choose "By Loose Parts".  This will separate all the leaves from each other.
When doing this with an object like the leaves on a tree be prepared to wait awhile for your computer to process this command as it can take some time due to the number of objects that need separating.  Also I suggest that when you select your leaf object right at the start you move this object to its own layer as you will have hundreds of individual leaf objects at the end of this process.  This will help when you follow the steps in the video you linked too.
My Renderosity Store
Virtual Furnishing
My Portfolio
kyraia ( ) posted Fri, 18 July 2014 at 1:08 AM
Hello keppel,
Cool! It worked. Thanks a lot.
Actually, I wanted to use this for an autumn or winter tree which doesn't have many leafs.
Kyraia
