Fri, Jan 24, 4:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Enviroment Dome. Gamma. PoserPro2014
timarender ( ) posted Thu, 31 July 2014 at 9:25 AM · edited Thu, 09 January 2025 at 3:53 PM
Forgive me if this is obvious. But I am confused.
I (think) that I understand that when using Enviroment Dome with PoserPro2014, that I should change the "value 1" values for "Gamma In" and "Gamma Out" from "2.2" to "1".
May I instead, simply delete the "Gamma In" and "Gamma Out" shaders?
bagginsbill ( ) posted Thu, 31 July 2014 at 9:47 AM · edited Thu, 31 July 2014 at 9:48 AM
Yes you could simplify quite a bit.
If you don't need any special effects, it is sufficient to plug the image into Ambient_Color (set the color chip to white) and adjust brightness with Ambient_Value. No other nodes are needed.
I like the HSV node in front, though, because I sometimes adjust saturation. (Usually to get more or less blue in a sky)
timarender ( ) posted Fri, 01 August 2014 at 9:12 AM
Many thanks.
