Sun, Jan 26, 10:20 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Poserscript function CurrentFile() ?
gbn ( ) posted Sun, 03 August 2014 at 1:55 PM · edited Sat, 25 January 2025 at 4:53 AM
I'm missing this function.
For normal use, it isn't needed since Poser session always knows its context (scene).
I'm using pickle-files for long w/ the same basename as the related Poser-file (render application).
I'm tired of explicitly give the current Poser-file name by dialogue-function.
Is there a trick by callbacks or monitoring AppData or shall I place a feature request ?
TIA / Gunnar
Pret-a-3D ( ) posted Sun, 03 August 2014 at 2:32 PM
This is only available in Poser 10 SR2 and above:
poser.Scene().DocumentPath()
Cheers.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
gbn ( ) posted Sun, 24 August 2014 at 12:32 PM
THX and check it: OK.
Needs to be updated in the PoserPython Ref Manual.
Not in REV May 13, 2013
-GBN-
