Sat, Jan 11, 3:33 PM CST
Subject: GND4 and Creature Creator addons
MoxieGraphix ( ) posted Fri, 01 August 2014 at 4:16 PM · edited Sat, 11 January 2025 at 9:16 AM
My google-fu is failing me. Has anybody done morphs for the creature creator addons (legs and tails) for GND4? Does anybody know?
MoxieGraphix ( ) posted Sun, 03 August 2014 at 2:18 AM
I've had minor success using the wardrobe wizard. Unfortunately, the mesh warps when the knees are bent (as in kneeling). I've tried different settings and had the most success converting it like shoes.
Is there an easier way to transfer the morphs onto the figure? I tried using Poser Pro 2014's built in "transfer morphs" bit, but I can't get the GND4 morph to transfer. The one time I did, it didn't change anything on the figure when applied. sighs
JimTS ( ) posted Sun, 03 August 2014 at 3:18 PM
You are going to have to rebuild the add on's joint work (digigrade legs right?)
also GND4 is still V4 so you inject the CC morphs like any V4
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
MoxieGraphix ( ) posted Sun, 03 August 2014 at 4:51 PM
Guess it's time to learn how to do some new (to me) things. Are there any decent tutorials for fixing te joint work?
The CC morphs on GND4 aren't the problem, it's transfering the GND4 morph to the legs where the problem is coming in.
MoxieGraphix ( ) posted Sun, 03 August 2014 at 7:45 PM
Ha. Well, after lots of fiddling and experimenting, I finally got it to work with copying the morphs from V4. So, consider this solved. I'll look for a tutoral later for fixing the joint work if I have to use the wardrobe wizard for a figure like that again.
Anyway, whew.
