Thu, Jan 9, 6:02 PM CST
Renderosity Forums / Suggestion Box
Welcome to the Suggestion Box Forum
Forum Moderators: msansing
Suggestion Box F.A.Q (Last Updated: 2025 Jan 06 12:26 am)
This forum is designed for suggestions from the community on how you feel we can improve Renderosity.
Subject: Possible new store error
Kazam561 ( ) posted Thu, 07 August 2014 at 9:02 AM · edited Thu, 09 January 2025 at 5:44 PM
I decided to try the option of the check box to prevent a new dialog button from occurring when I remove an item from my cart. The page loads with this only
{"success":false,"response":"Caught exception: The item does not currently exist in your cart."}
There's no other text or option for me to return to the newly adjusted cart other than for me to press my browsers back button or reopen the address manually and then go to the shopping cart. Surely (I can't help it, don't call me Shirley, Leslie Neilson fan) this isn't working as intended? It seems like the page should auto refresh but doesn't. Just a heads up. Not meaning to sound grumpy with complaints. Just trying to spend money :D
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Kazam561 ( ) posted Thu, 07 August 2014 at 9:05 AM
Update, okay, I've reopened the website and cart and now it appears to be working normally. The first time you do the option however goes to a white page with the text mentioned in the previous post.
KimberlyC ( ) posted Fri, 08 August 2014 at 11:31 AM
I'm glad it is working for you now. Thanks for bringing this up!
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
Kazam561 ( ) posted Fri, 08 August 2014 at 11:59 AM
No problem :) I actually still see a page occassionally not load after the button's pressed to remove the item. It'll just load a blank gray page (with the upper and right frame, but nothing where the cart should be.....
