Sun, Feb 16, 11:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Porcelain
Zaarin ( ) posted Thu, 24 July 2014 at 2:51 PM · edited Sun, 16 February 2025 at 11:54 PM
Anyone have some advice for a porcelain shader? Not the really shiny porcelain used for toilets and bathtubs but the softer porcelain used for dolls and china. I suspect a scatter node is involved, but beyond that I'm not quite certain. :/
(On an unrelated note, I'm also looking for an M4 character with Baroque makeup. I have three or four for V4, but I can't seem to find any for M4.)
ghostman ( ) posted Thu, 24 July 2014 at 2:55 PM · edited Thu, 24 July 2014 at 2:56 PM
Any one these have a porcelain shader in it. You can tweak it til you have something you like.
http://www.renderosity.com/mod/freestuff/?item_id=69141
http://www.renderosity.com/mod/freestuff/?item_id=69176
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
Zaarin ( ) posted Thu, 24 July 2014 at 5:25 PM
But again that's glossy porcelain. I have Bagginsbill's glossy shader; I'm sure I could tweak it into glossy porcelain. What I'm looking for is the type of porcelain one would find in a porcelain doll.
Miss Nancy ( ) posted Thu, 24 July 2014 at 5:29 PM
you mean like clay node?  non-shiny
bagginsbill ( ) posted Thu, 24 July 2014 at 5:43 PM · edited Thu, 24 July 2014 at 5:44 PM
Like this one? Note this is NOT my image. This is a photo of a real porcelain doll.
I'm just showing it to ask if this is what you mean.
If it isn't, then show one, please.
Zaarin ( ) posted Thu, 24 July 2014 at 7:02 PM
Yes, what Bagginsbill posted is exactly what I'm looking for.
bagginsbill ( ) posted Thu, 24 July 2014 at 10:04 PM
Hmm. A few dozen attempts and I still don't have it.
Zaarin ( ) posted Fri, 25 July 2014 at 10:25 AM
It does seem to be a complicated material.
vilters ( ) posted Fri, 25 July 2014 at 10:41 AM · edited Fri, 25 July 2014 at 10:48 AM
Not Porselain, but the closest I ever did was this.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2857390
All images can be enlarged, from simple shader setup, to a bit more complicated.
BB will certainly come with a far better result.
happy Posering
bagginsbill ( ) posted Fri, 25 July 2014 at 1:30 PM · edited Fri, 25 July 2014 at 1:31 PM
There's no gloss on what Zaarin wants. None.
There may be some very soft, very spread out, blurry specularity, but it's not the main feature of the material.
The main feature is the way in which light scatters. I am able to get lots of translucence and scattering, but it doesn't have the right character. I can't put my finger on what's not right, but it isn't the same.
I have a suspicion that Poser's SSS approximation is not matched to the particular character of this real-world material. But I'm not saying that yet. I'm often irritated by other people saying Poser can't do something when it's more an issue that the user doesn't know how to do the effect.
I usually know, but in this case I don't. Which may mean it can't be done, or it may mean it's unusual enough that getting Poser to do this particular effect is something I've never run into before, and I have to try more things.
Miss Nancy ( ) posted Fri, 25 July 2014 at 1:32 PM · edited Fri, 25 July 2014 at 1:37 PM
I nearly got it with snarly's EZMat/EZskin.  drop scatter scale so it's more translucent than skin.  I tried scale= 0.1 on both scatter nodes, but it was so strong it was hard to see nose in render.  delete texmaps, use procedural bump (which is almost wiped out by increased scatter). add slight orange to hsv node to compensate for blue scatter.  decrease reflect node softness and incr. blinn refl.,  both of which you can hardly see due to scatter.
would also be good chance to post demo render using new VSS, or new porcelain plug-in for EZMat.
Miss Nancy ( ) posted Fri, 25 July 2014 at 2:57 PM
using above settings, it looks like this.  but it's too strong for facial features, hence will need to modify it.   dunno if it's o.k. with snarly to post screen shot of edited shader in mat room.
porcelain shader
bagginsbill ( ) posted Fri, 25 July 2014 at 3:28 PM
Quote - I nearly got it with snarly's EZMat/EZskin
I see we mean different things when you say "nearly" and I say "nearly".
Quote - but it's too strong for facial features
Yea well that is what I was looking at in my attempts and it is not even close to the photo I posted.
bagginsbill ( ) posted Fri, 25 July 2014 at 3:40 PM
This is what I'm getting. Notice the blue in the nose? At these very long scatter distances, funny stuff is happening.
Snarlygribbly ( ) posted Fri, 25 July 2014 at 4:02 PM
Quote - ...
If someone does come up with a convincing porcelain shader and is kind enough to post the shader for public use, then I shall start a thread giving a mini tutorial on how to convert it to a working EZMat plugin :-)
Free stuff @ https://poser.cobrablade.net/
bagginsbill ( ) posted Fri, 25 July 2014 at 4:08 PM
Well I'm not happy with this, but for what it's worth, this is what I was using.
The tint color in the scatter was attempting to cancel the color map blue a bit - that's not going to be the same if you're not using a color map or you're using a different one.
Some of the numbers are overly precise - I didn't type those - they come from matmatic based on a formula.
Zaarin ( ) posted Fri, 25 July 2014 at 4:12 PM
Thanks, I'll fiddle around with it and see what I get. :)
icandy265 ( ) posted Sun, 27 July 2014 at 1:49 AM
This is what I got... I pretty much stuck to BB's shader, except that I used a Color Math instead of a Blender node, and I used these Scatter settings:
Scatter Preset - Skimmilk
Texture Detail - 0.400000
Scale - 0.350000
MaxError - 0.200000
Scatter Color - Very light pink-orange
Also the lighting played a huge part in getting this look. I used a Fill Light (Infinite at 45% Intensity) and 2 Backlights or Rimlights (Infinite at 60% Intensity on both). The Backlights were placed directly behind her ears and casting slightly over her shoulders. Both Backlights have Shadows turned Off. The Fill Light is the only light with Shadows, and it uses Raytraced Shadows with Shadow Samples set to 40.
Indirect Lighting is on but only at 0.4% Intensity (using the D3D Render Firefly script), as well as Subsurface Scattering.
Gremalkyn ( ) posted Wed, 30 July 2014 at 1:22 PM
Attached Link: The Doll
This image by fu-minn has a bit of shine.  The texture is by the artist.
Miss Nancy ( ) posted Wed, 30 July 2014 at 3:04 PM
looks good, icandy.  no bluenose nor blue ears!
Zaarin ( ) posted Fri, 01 August 2014 at 1:27 PM · edited Fri, 01 August 2014 at 1:29 PM
So, I finally got around to testing out the shader Bagginsbill posted and these are the results. This is basically the exact shader BB posted with two changes: no HSV node to reduce saturation (the texture was already white) and scatter is set to "skimmilk" instead of "potato" (I tried both "potato" and "marble" as well, but I liked the results from "skimmilk" the best--the marble looked too crisp and the potato looked too warm). I think the results are quite satisfactory for my purpose. :)
ETA: The rest of the shaders are untouched except using EZMat for all the things one should use EZMat for. Also, the jingles use a metal shader by BB from one of Dreamland Models sets I think; I forget which. And I used BB's eye shader for the eyes but set the scatter mode to marble rather than skin. The lighting setup is an HDRI image and two spot lights.
LadyElf ( ) posted Sat, 02 August 2014 at 5:19 PM
Oh I really like this :) Nice work !
Snarlygribbly ( ) posted Tue, 05 August 2014 at 10:41 AM
As promised, I made a tutorial on how to convert this shader to an EZMat plugin:
Porcelain tutorial
aRtBee ( ) posted Tue, 05 August 2014 at 3:17 PM
hi all,
I'm not in the position of testing at the moment, but as I read the posts, it crosses my mind that Custom_Scatter might be the alternative way to investigate, instead of Scatter.
The latter produces a blue/cyanic teint in all presets, the least for Marble (see table, the vales are a response to only a direct infinite light at 85%, producing 245/245/245 for regular 100% diffuse white under Gamma 2.2).
Note that the color in Custom Scatter is an absorbing one, using red makes a cyaning teint as red is taken out etcetera. White dims and makes a neutral translucency, black means no absorption in the skin layer at all.
Serous thickness settings are required, try 32, 64, 128, 256 to get a feel for it.
Just thinking out loud...
bagginsbill ( ) posted Tue, 05 August 2014 at 4:21 PM · edited Tue, 05 August 2014 at 4:23 PM
Good idea but the custom scatter does the opposite-color tint as well. In fact, it's worse.
The lack of math description for custom scatter results in me guessing what it's doing and ending up wasting a ton of time.
The dipole scattering approximation it seems to be using is flawed, IMO. The numerous situations of white material with colored scatter (chromatically heterogeneous dispersion and absorption) producing opposite colors are bogus.
If blue is absorbed, causing scattered light to appear red, then there is no place where more blue should suddenly show up. It's not a zero sum game. Yet that is what it does. Bogus. A red scattering coefficient indicates an increased absorption of blue versus that of red. It does not, in any way shape or form, suggest that in some directions, scattering amplifies the blue.
aRtBee ( ) posted Wed, 06 August 2014 at 1:41 AM
yeah I know it''s hassling with the inverse scatter color too. But when that scatter color is a shade of white/grey it makes a neat uncolored translucency. Which might come in handy in the particular case from this thread, as Scatter requires your inverse-color-reversal and so on. I''ll look into it, soon.
Hana-Hanabi ( ) posted Mon, 11 August 2014 at 11:30 AM
Bill, if it helps, I think the picture of the doll you posted is made of french resin, not porcelain. (I don't know if you were looking up mathy-things for porcelain, and then not getting the desired results...But if so, it would be because that's not porcelain.)
花 | 美 | 花美 | 花火
...It's a pun.
aRtBee ( ) posted Mon, 11 August 2014 at 1:57 PM
This?
aRtBee ( ) posted Mon, 11 August 2014 at 2:03 PM
same setup, just with a 75/25 grey tiling base texture to demonstrate the scattering.
aRtBee ( ) posted Mon, 11 August 2014 at 2:25 PM
same setup, but... - pawn head: just reduced the scattering a lot to show the tiling base texture itself - pawn neck: reduced scattering - body & foot: same as above for reference - pawn base: just used a pinkish scatter color
After two weeks of testing in Muppets lab: Custom Scatter is great fun. The Scatter node is just a specialized subset of it, I can recreate every Scatter preset result (including artefacts), and do more. I understand its workings, its issues and its shortcomings, and I understand the effect of IDL and GC on its results as well. I just have to figure out one option/parameter...
... whoa, where are my asperines?
aRtBee ( ) posted Mon, 11 August 2014 at 2:32 PM
okay then, the boring part.
Settings for the pawn body (middle area). In the first image it's the setup for all pawn parts, but without the tiling node.
Zaarin ( ) posted Mon, 11 August 2014 at 2:56 PM
Wow, that's quite impressive; it looks good. :D
aRtBee ( ) posted Mon, 11 August 2014 at 3:57 PM
thanks.
In case someone wonders: this is the color/diffuse part only, I did not add specular/reflect in yet. That should be done the regular way, using Fresnel etc. Right now, this is the result of my investigations on Scatter as a Diffuse-replacement only.
Sorry for not including that.
Also for the sake of this test-render-result: render gamma set to 2.2 and IDL off. As said, I found out that GC and IDL do affect the scatter-mechanism / result as such, not only brightness and coloring.
And yes, node settings do depend on object geometry (same translucency on different object requires adjusted settings) and no, math/physics models are not applicable. Poser is serving a bag of graphics tricks again. So being good in graphics and bad in math might make one a decent manager of the Poser scatter nodes :-)
