Sat, Jan 4, 5:02 PM CST
Subject: Freak 4 problem on Poser Pro 2010
giotim ( ) posted Sat, 26 July 2014 at 8:46 AM · edited Thu, 02 January 2025 at 8:40 AM
Hi guys, i really hope to have choose the right forum section for my question:
For first sorry about my english, it's awful, i know...the question is about The Freak 4 on Poser Pro 2010:
I select it on the library:
Click image for larger version.  Name: 1.jpg  Views: 2  Size: 15.1 KB  ID: 102847
and when i click it this is what happen:
Click image for larger version.  Name: 2.jpg  Views: 2  Size: 38.7 KB  ID: 102848
It's like it open Freak's head, but not the whole huge body, the body is the one from Michael 4, and i'm not able to modyfy it in any way.
I have all the Michael 4's stuff, morph, musclels, etc.
Can someone help me?
Thank you!
hborre ( ) posted Sat, 26 July 2014 at 10:04 AM
Did you reinitialize Michael 4 after installing Freak 4?  Freak 4 loads fine in my setup.  Either update or reinitialize M4 and try again.  To update, you need to run this bat file, DzCreateExPFile-M4 found under !DAZ folder in Libraries.
giotim ( ) posted Sat, 26 July 2014 at 10:38 AM
Quote - Did you reinitialize Michael 4 after installing Freak 4?  Freak 4 loads fine in my setup.  Either update or reinitialize M4 and try again.  To update, you need to run this bat file, DzCreateExPFile-M4 found under !DAZ folder in Libraries.
Thank you man, you saved my life!
I had no idea of this reinitialize thing, i did not find this solution in the installation files, thank you very much!
hborre ( ) posted Sat, 26 July 2014 at 11:08 AM
Reinitializing is necessary after every new morph pack is installed which includes character morphs like Aiko 4, etc.  This will create the extra channels to load the morph files.
estherau ( ) posted Mon, 28 July 2014 at 9:55 AM
Let us know if you get a problem where his shoulders join his arms and we can help you with that as well.
Love esther
PS I liked him best with Y scale in legs and thighs increased to 107, pelvis to 103 and abdo up a bit too.
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Mon, 28 July 2014 at 9:56 AM
to make scaling changes you have to reveal the dials which can be done by selecting the body and then in the parameters panel there is a little arrow top right and you will see a command to show the various hidden dials.
giotim ( ) posted Thu, 31 July 2014 at 11:24 AM
Thank you Estherau!
By the way, i have a little problem, i created my freak character based on M4, but i'm not able to move his feet:
if i click the right foot for example and try to drag it with the "translate/pull" tool, it move in a weird way, not well as a normal M4 character.
This thing is more visible if i click the right foot, and then i go to the "Parameters" bar on the right, and moving the various X, Y, Z axis, they remain on 0,000 without changing, without moving, the foot remain on its beggining position.
Can you help me?
thanks
hborre ( ) posted Thu, 31 July 2014 at 12:24 PM
Check if IK is turned on.  It is usually on by default and it could be the source of your problem.
giotim ( ) posted Thu, 31 July 2014 at 1:12 PM
I'm sorry hborre, what is "IK"?
Miss Nancy ( ) posted Thu, 31 July 2014 at 2:28 PM
see att img
giotim ( ) posted Thu, 31 July 2014 at 3:23 PM
Thank you guys, solved!
I'm sorry i'm still new with poser...
giotim ( ) posted Tue, 12 August 2014 at 2:56 AM
I'm sorry to bother you all again, i have another problem:
I'd like to morph Michael 4.
I'm able to open him (top pic) , add the morph, and, as in the attachment, add some muscles to him (middle pic) but i don't know how to, for example, enlarge his shoulders. It's like the muscles increase, but the skeleton distances under him remain the same, the bottom pic is what i would like to do (made in PS).
Can you help me?
hborre ( ) posted Tue, 12 August 2014 at 8:14 AM
With such morphs, you will not obtain a corrected pose to compensate.  You will need to adjust the pose manually using joint rotations and positions.  Select the body area you are interested in changing and try spinning a few dials.
giotim ( ) posted Fri, 15 August 2014 at 1:16 AM
Thank you hborre!
