Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
Without more specific information, I suggest that your problem is that you're either:
a) Missing needed textures :or
b)you've mislocated them.
Check your read me's and see if you can follow the texture path back to the source file.
Also, check to see if you've got all the files you need and that you've loaded them in the right place.
I downloaded the files from HIvewire, then I put them in a folder called Hivewire horse.
Then I unzipped them and created an external runtime (just like all my other runtimes) on my external drive and linked it to Poser. All my other external runtimes work fine this way. I did not misplace any textures. I installed each runtime from HIvewire right into the main HIvewire Horse runtime. Could the external drive cause problems? Thanks
Do you have the current version of the HW Horse? He's had a few updates since release.
I have him installed in an external runtime, and so far he's worked just fine.
You open the file that failed to load the texture (in notepad) and search the textures and correct the file references
It's in your setup they all load fine on my rig where no resources are installed on C: l
D:poser pro 2014
G: RuntimesPeople Creatures
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Poser Pro 2014 says it is missing textures. Also the Arabian is missing textures. I see other people using the horse with no problem, What do you think is wrong? Anyone else have this problems? Thanks, Sherrie
