Thu, Nov 28, 2:50 PM CST
Subject: character window stuck in upper left
robs ( ) posted Sat, 29 September 2001 at 6:15 PM ยท edited Thu, 28 November 2024 at 11:56 AM
Hi, I somehow got my Poser character window up in the very top left of the Poser screen. Since I cannot get at the upper left of the window (it is under the menu) I cannot drag it down again. I have tried: - setting preferences to factory on launch - loading other .pz3 files Always the window stays in the upper left. Can anyone suggest how I might get it back in the center of the Poser screen. Thanks, Rob (running ProPack)
Nance ( ) posted Sat, 29 September 2001 at 7:11 PM
Just to confirm: -Document Preference = Launch to Factory State -Interface preference = Use Factory State and do not hit "Set Preferred State" until you get it back to normal. Then close the whole app and reopen.
Nance ( ) posted Sat, 29 September 2001 at 7:13 PM
Just noticed you said propak - that was for P4 - don't know if it's different.
ScottA ( ) posted Sat, 29 September 2001 at 7:38 PM
Common problem.....Simple fix: 1.)go to your Poser4->Runtime->prefs folder on your HD 2.)delete your PreferredState.pz3 file When you open Poser. It will be back to square one and you can reset the way you want it to look. ScottA
robs ( ) posted Sat, 29 September 2001 at 7:49 PM
Ah, I had set Launch to Factory State but not Use Factory State With both set a restart fixed the problem. Thanks all. Rob
jamball77 ( ) posted Sat, 29 September 2001 at 10:42 PM
When you have everything the way you want it Set a UI button. Then the next time this happens you just bring up your UI buttons and click to bring up your preferred settings.
