Fri, Nov 22, 12:35 PM CST
Subject: where is the obj file?
itsmingg ( ) posted Sun, 21 September 2014 at 3:11 AM · edited Fri, 22 November 2024 at 7:33 AM
Hi,
I'm trying to locate the cat obj file. I checked the CR2 and it point to the
runtimes/libraries/characters/animals/pets/ ......
but it wasn't there !
Anyone can advise ?
TKS!
Fugazi1968 ( ) posted Sun, 21 September 2014 at 4:43 AM
Hi
Its the Housecat.obz file near the bottom of the list.  As I recall an obz is a compressed obj. I hope that helps
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
rokket ( ) posted Sun, 21 September 2014 at 11:18 PM
If you want to use the obj, you'll have to run the script to uncompress all your Poser files. an obz is the compressed obj file.
I am not on my Poser machine, but I believe you look under Scripts and it should be there.
It will ask you if you want to delete the compressed files after you run it.
itsmingg ( ) posted Sun, 21 September 2014 at 11:32 PM
yes . i run the uncompress script and it works !
thanks for all help !
rokket ( ) posted Mon, 22 September 2014 at 6:39 AM
Good, I am glad you figured it out.
