Vue F.A.Q (Last Updated: 2024 Jun 25 7:29 pm)
A fractal used for transparency will work like this: where the fractal function returns black (-1), 100% transparency, where it returns white (1.0), whith variable transparency for the grey values inbetween (the whiter, the more visible), so a fractal is of no use for what you need. You need to create an alpha mask in a paint program and apply the mask in Vue
![file_507791.jpg](https://live.cdn.renderosity.com/forum/threads/2885417/file_507791.jpg)
Hello all,I'm trying to make the edges of an object (a plane) 100% transparent but i did not succeed so far.
When you apply a fractal (that has transparenty) to a plane, you can still tell by looking at the edges that it is a plane. (see the attached image)
Is there any way that you can apply for example something like a "transparent from the center" of the plane (object) ?
Or even better, can you apply an edge transparency with a fractal itself ?
Thanks
Wim :-)
Society failed to tolerate me...
... and i have failed to tolerate society
