Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
As willyb53 says, under help click on personalize, type the new serial number you got with your Game Dev purchase and click OK. The new features should now appear and the start up flash screen will change to the Game Dev version.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Quote - Thank you. Should I have known that? I did not see that information anywhere, I don't think I could have discovered this withoug your help. Thanks.
Your welcome. You are not alone, I had the same problem and I know others did as well. The method is outlined in the addendum but you need to be able to find that and I am not sure the link appears under help until after you have activated Game Dev.
If it is a download version you also need to download and install the support files to get the addendum, another step I forgot first time around.
So,
I upgraded from 2014 to the game version because of the good price. How can I tell I have it? I don't see any difference. I downloaded the file, installed it, but it says nothing about the game version.
Thanks,
Joey
