Mon, Nov 25, 11:43 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Lighting issues
manleystanley ( ) posted Fri, 31 October 2014 at 2:48 PM · edited Mon, 25 November 2024 at 11:40 AM
Well lets see if this goes this time. I'm sure I was hitting the wrong "new thread" button embarrassed-smiley07
I'm having soft shadow issues in the macabre render "night nurse". It's going up today regardless, but if you check this render I am using a spot light for moon light through the window. You can see the soft shadow of the window panes but the shadow from the character is sharp. It seems the soft shadows are lost going through the glass.  I've worked with the light and the glass shaider but haven't figured out a solution, so any suggestions would be appreciated.
file_5f93f983524def3dca464469d2cf9f3e.jp
dr_bernie ( ) posted Fri, 31 October 2014 at 4:14 PM
I think I know the reason why. In a very peculiar way Carrara is trying to tell you that this is a sick image and that you should abstain from posting it.
manleystanley ( ) posted Fri, 31 October 2014 at 5:01 PM
If I wanted any crap from you I'd squeeze your head.
manleystanley ( ) posted Fri, 31 October 2014 at 5:54 PM
halloweensmiley_13
booksbydavid ( ) posted Fri, 31 October 2014 at 7:58 PM
I'm only guessing, but you might try turning off the material for the glass. Maybe, for some bizarre reason, the soft shadows are cancelled after going through the glass. (I'm assuming there is glass in the window)
manleystanley ( ) posted Fri, 31 October 2014 at 10:49 PM
I can't turn off the material; shaider zone, as far as I know, but I can take the model in to the modeling room and remove the window glass. Didn't fix it 3531a34faafcd3d5ab8749a94f57319e
Next try lets get ridicules light settings.with the settings. halloweensmiley_37
Kixum ( ) posted Sat, 01 November 2014 at 3:13 AM
Carrara softens a shadow based on the distance an object is from the other object receiving the shadow just like in real life.  Try usng a distance light with ray traced soft shadows and a radius of 100.  I doubt it will help but you can give it a shot.
-Kix
manleystanley ( ) posted Sat, 01 November 2014 at 8:38 AM · edited Sat, 01 November 2014 at 8:39 AM
Yes, after working with it a bit I realized that the window is 3X further from the figure then the figure is from the door. So the shadows may be realistically right, but they just don't look right. I've had it rendering since last night, this may be an 18 hour render. I'll post it once done.
Swamping the spot with a distance light wont work in this set up, I removed the roof for a better HDRI effect. But I will agree, if you are having a perplexing lighting problem change your light type. I wasn't getting the effect I wanted from the over head shaped lights I had in the florescent fixture models, so I changed it to a spot and used the barn doors to give the light the right shape; long/thin. Worked like a charm.
Seems I learn a little bit from almost every render I do. computer_smiley5
manleystanley ( ) posted Sun, 02 November 2014 at 8:13 AM
It's up. Turned in to a 26 hour render, so raytracing was out of the question.
I'd love a render farm of i7's with 16gig happy-smiley26
