Wed, Jan 22, 11:32 PM CST
Subject: Advice for the environment of a scene
jayisthemasternow ( ) posted Tue, 11 November 2014 at 8:52 AM · edited Wed, 08 January 2025 at 6:43 PM
 I was wondering if anyone has some advice on how to make the environment for my scenes? I am using poser 8 and would rather not pay for the vue program right now to make the environment. But the biggest problem I would like solved is the issue of the horizon. I know I could use the worldball type prop, but I am looking for something a little different.
Anthanasius ( ) posted Tue, 11 November 2014 at 10:22 AM
 Hi
You never use envsphere with equirectangular picture ? You can found thousands environment here  https://www.flickr.com/groups/equirectangular/pool/
Génération mobiles Le Forum / Le Site
moriador ( ) posted Tue, 11 November 2014 at 12:26 PM · edited Tue, 11 November 2014 at 12:31 PM
When you say you're looking for something "a little different', I think you need to be more specific. How different?
Most of us an environment sphere with equirectangular images, as noted. Over at Daz, Flipmode has made a Skybox that is itself rectangular, but functions like a sphere.
Or are you talking about the terrain -- the thing people actually stand on?
Edit: Or are you talking about using actual PROPS to simulate a horizon, such as hills and mountains?
If it's the last one, there are some potential pitfalls, as the scaling will be off. For example, I once made a very lovely scene with gorgeous, realistic looking mountains on the horizon. It looked great. Until I put some buildings in and rendered, and realized that my buildings were casting shadows on my mountains. LOLOL.
Hence the environment sphere, because you avoid such issues.
DrNewcenstein ( ) posted Tue, 11 November 2014 at 12:56 PM
 Look beyond Vue.
Bryce takes work to integrate into Poser, but it  works well, when it works.
Alternatively you can spend weeks sifting through a ton of free models at Turbosquid or here, then trying to make them work.
seachnasaigh ( ) posted Tue, 11 November 2014 at 2:39 PM
     I have some modeled terrain enviros with wall/dome enclosures.  Some are posted in the freebies here here (Galadriel's mirror, Eldar house, Tink's Cafe')  The updated version of Lothlorien isn't released yet - it's massive.
hborre ( ) posted Tue, 11 November 2014 at 3:47 PM
Terradome @ RDNA if you are looking at meshed terrain/environment.
jayisthemasternow ( ) posted Tue, 11 November 2014 at 7:15 PM
Well, to be honest I am able to make the spot the figure stands on. But I am not quite sure how to get it to fade into the background in a way that makes it look natural.
hborre ( ) posted Wed, 12 November 2014 at 8:34 AM
Do you mean using Depth of Field?
jayisthemasternow ( ) posted Wed, 12 November 2014 at 10:09 AM
 Hi
This is actually what I needed. But the photos at the flickr link you gave are too small it seems. They end up all pixilated on the render. I tried the hdr image in the instructions on how to use the env sphere and it came out great (you know the whole lake scene). But if I need to get other equirectangular pictures, what size should they be? Also, am I missing something about how to find good images on flicker for it?
ghonma ( ) posted Wed, 12 November 2014 at 10:48 AM
For free, the highest rez images you can get are to be found at the sIBL site:
http://www.hdrlabs.com/sibl/archive.html
Dosch has a bunch of high quality sets but they aren't cheap:
http://www.doschdesign.com/products/hdri
You can also try searching for 'hdri' in google image search.
seachnasaigh ( ) posted Wed, 12 November 2014 at 11:32 AM
     I often use a ground plane prop which fades to transparent at the outer edges,  would something like that be what you had in mind?
FightingWolf ( ) posted Wed, 12 November 2014 at 11:41 AM
When I create large environments inside of Poser I use the Focal settings of the camera to create the illusion of distance and pull the camera back to increase the width of the scene.   Here's an example that shows this method on making it appear as if someone is high up looking down.  If I wanted to make the city look vast then I would point the camera towards the horizon instead of the ground.   The posing camera or the dolly camera should be used to create this effect.  The main camera produces a flat look and you can't adjust the Focal settings.   You can combine this technique along with the focal distance to help determine what parts of your environment you want your viewer to focus on. This method will probably work best with some sort of environment dome.
moriador ( ) posted Wed, 12 November 2014 at 3:12 PM · edited Wed, 12 November 2014 at 3:13 PM
Ah, yeah. You need a terrain that is big enough to reach the edge of your sphere (or look like it does), and textures for the terrain that match the image on the sphere very well. The first isn't too hard; the second is the real challenge. And it's why whenever a vendor offers a matching set that looks good to me, I'll buy it. Other than that, you can cheat by completely obscuring the "horizon" with objects like buildings, rocks, trees, etc.
icprncss2 ( ) posted Thu, 13 November 2014 at 1:42 PM
Try turning on the depth cue.  Also try adding atmosphere.  Even light fog or smoke can help soften the distance.
moriador ( ) posted Fri, 14 November 2014 at 9:08 AM
Depth cue renders fast. No good for God rays, but for fading the background, I agree with icprncss2. The trick, I think, to the depth cue is to moderate its intensity. For me, the longer the distance between the start and end point, the thinner the density. So if I start with a distance of 5m and end with 350m, it's much more subtle than if I start with 5m and end with 20m.
Another possibility is to add a water plane -- with a good BB water shader -- to meet the horizon line. It's frequently very convincing. You can usually justify a little strip of water in the distance in almost any landscape. :)
