I was looking for "God Rays" somewhat like that a little more dispersion, but I'm hoping to get them to be created by the slats blocking the light.
I've changed the lights from point to spot and gotten better results, and the falloff did separate them more, now I'm trying to get them to NOT wash out the rest of the image.
Getting there, but pointing them in the right directions is helping, it gives the rays more in the background without washing out the foreground.
Thanks!
in addition:
idea 1: lights have an Atmosphere Strength parameter, when you increase it (massively, 0.1 at least) you get more effect from the light, or: for the same effect you can do with less fog
idea 2: the Scripts menu holds an procedure to render per light. The you can combine the results in post, using layers in Screen (or Bleach) mode in your Photoshop or alike. That gives full control without re-rendering.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Hi!
Poser 2012 pro.
I have a point light inside a cage with slats instead of bars.
Point light emanates from within cage, casting shadows on the walls, the slats blocking the light as it should be.
If I increase atmosphere I get better rays, but increased atmosphere tends to wash out the rest of the image.
Is there a way to get nice distinct rays without increasing the atmosphere?
Thanks
