Wed, Jan 8, 5:43 PM CST
Subject: Problem she freak scale upper body
aldebaran40 ( ) posted Mon, 05 January 2015 at 7:40 AM · edited Sun, 05 January 2025 at 9:13 PM
Like their male vercion, she freak has problems when you scale your upper body  (Figure 1), try following the solution that I applies and worked in male Freak:
  1. open up the freak,
  2. bring up the joint editor,
  3. select the chest,
  4. select the lCollar scale zone,
  5. press the button to fix mismatched scale zones, the problem corrects.
  6. select the rCollar actor
  7. select the chest smooth zone in the joint editor
  8. press the button to fix mismatched scale zone.
but only solves the problem in her right arm, ¿any idea how to fix it in both arms?
If I copy the symmetry from right to left that will not bring me problems in the future?
Thanks in advance
file_06409663226af2f3114485aa4e0a23b4.jpfile_3def184ad8f4755ff269862ea77393dd.jp
MistyLaraCarrara ( ) posted Mon, 05 January 2015 at 7:03 PM · edited Mon, 05 January 2015 at 7:05 PM
thats the single axis scaling bug.
i apply the SF morphs without the scaling. wasn't worth the aggravation, imo
button to fix mismatched scale zone - is that new for pp14?
aldebaran40 ( ) posted Tue, 06 January 2015 at 8:02 AM · edited Tue, 06 January 2015 at 8:04 AM
I have found that I can fix this problem using symmetry from right to left, so do not know if this can damage the model in the future ,
I will not have problems with joint area ?
file_903ce9225fca3e988c2af215d4e544d3.jpfile_65ded5353c5ee48d0b7d48c591b8f430.jpfile_38af86134b65d0f10fe33d30dd76442e.jp
