Try removing ray-trace from the wings. That solved the issues I had with them some time ago.
Angelyna Wings
TIP: The wings appear gray when the light shines directly on them (at a 90%) when the wings are facing fat to your perspective. Shine a light at an angle to the wings to make them white.
Robert
What version of Poser are you using? Below is a picture that I created a long time ago using Angelyna Wings and Poser 7 or 6.
Damn that looks good. I use Poser 7.
The part i don´t understand is, when you render the wings you can see the pink and green a bit shinging through the black color
(i used pink and green for example render)
I have a problem with the angelyna wings from the freestuff here.
After i added them to a poser scene you can color it like you want, if you render the color is always dark
even when you put the biggest spotlight on it.
Whats wrong?
