Mon, Jan 20, 3:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: upper brow blue hue?
Boni ( ) posted Fri, 06 March 2015 at 4:31 PM · edited Mon, 20 January 2025 at 3:56 PM
posted an image ... then realized I had a blue hue on the upper brow. (thanks to a friend who pointed that out). Here is the image and settings.  I've been playing with the transparency settings and nothing seems to help.  Advice?
The image:
file_7e7757b1e12abcb736ab9a754ffb617a.pn
The settings:
file_1c9ac0159c94d8d0cbedc973445af2da.pn
Boni
icprncss2 ( ) posted Fri, 06 March 2015 at 5:44 PM
Try setting the transparency edge and fall off to zero.
Boni ( ) posted Fri, 06 March 2015 at 6:32 PM
Tried that to no avail ... but I changed the alternate diffuse color to white and that took care of it ... now ... I'm just wondering why for future reference.
Boni
hborre ( ) posted Fri, 06 March 2015 at 6:44 PM
Did you try setting the diffuse value to 0 rather than using both diffuse_color and Alt_diffuse?
Medzinatar ( ) posted Fri, 06 March 2015 at 7:15 PM
The problem might be with the Scatter group ID.
Is it the same or different as other skin nodes?
Boni ( ) posted Sat, 07 March 2015 at 9:45 AM
I'll look into that ... I'm just glad that making the alternate diffuse white fixed it without having to change the color of the diffuse as that colors the brow (I don't have a lower brow on this figure so that the user can change colors at will).
Boni
Morkonan ( ) posted Sat, 07 March 2015 at 9:57 AM
Just a note: Make sure that the gamma value for all black and white maps (trans, spec, bum, etc) is set to 1. By default, it's set to 2.2, IIRC.
Boni ( ) posted Sat, 07 March 2015 at 10:19 AM · edited Sat, 07 March 2015 at 10:20 AM
Actually for this brow to "show up" I have to set the gamma to .5.  bagginsbill has a comment about that in another thread I had on balancing gamma and transparencies.  I can't find the thread at the moment.
Boni
bagginsbill ( ) posted Sat, 07 March 2015 at 10:23 AM · edited Sat, 07 March 2015 at 10:24 AM
You have a lot going on in this shader and almost all of it should not be there. I can't see all the connections, so I cannot tell what it's trying to do, but neither do I need to.
Here's what you should have:
Transparency, value = 1, plug in the trans map.
Transparency_Falloff = 0, nothing plugged in.
Diffuse_Color set to what color reflects from the eyebrow hairs. Diffuse_Value adjusted to get whatever adjusted brightness of that color you desired. 1 is fine if you really mean for the color to be exactly that.
Everything else should be deleted and I mean it. This part is not a closed surface and should not have scatter at all. This part is hair and does not reflect the environment enough to justify the computational cost of soft reflections.
The part is already offset (raised) off the forehead so displacement is not needed.
I am suspicious that some of that transmap that should be black isn't black.
Boni ( ) posted Sat, 07 March 2015 at 10:26 AM
I was wondering about that ... EZskin as much as I really like it over does sometimes.  Thanks for the information bagginsbill.
Boni
Boni ( ) posted Sat, 07 March 2015 at 10:47 AM
Did a partial render ... much better ... show more on Monday ... busy weekend. :)
Boni
Boni ( ) posted Mon, 09 March 2015 at 11:28 AM
After a busy weekend ... here is my render from bb's advice. :) file_3988c7f88ebcb58c6ce932b957b6f332.pn
Boni
Morkonan ( ) posted Tue, 10 March 2015 at 1:59 PM
What appeared to be the issue?
Boni ( ) posted Tue, 10 March 2015 at 3:01 PM
If you see in the original image at the top, there was a blue hue to the brow section, I not only wanted to rid my figure of that but know why it happened to avoid it in the future.  I think I've accomplished that.
Boni
Morkonan ( ) posted Thu, 12 March 2015 at 6:07 PM
That's great, but what was the issue that was causing that? Was it because the transmap was loaded with an improper gamma or was it something more complex?
Boni ( ) posted Thu, 12 March 2015 at 6:37 PM
EZskin2 adds a lot of unnecessary properties to the alt-diffuse.  I deleted them all and fixed the issue completely.  Pllus I lightened the foot-print of the textures. :)
Boni
ElZagna ( ) posted Fri, 13 March 2015 at 1:50 PM
...or try this: Open up the Hierarchy window and take a look at Victoria's settings. Right underneath "Head" you should see "Eyebrow". Make sure it's set to invisible. That's it.
Now if you make Victoria invisible through the Hierarchy window by clicking the visibility icon of her "Body" or "Victoria" herself, and then make her visible again, you'll see the eyebrow problem again. I'm not really sure why she has an eyebrow.
OS: Windows 10 64-bit, Poser: 10
Boni ( ) posted Fri, 13 March 2015 at 5:19 PM
Um ... if I set eyebrow to invisible the upper brow that I've created with the transparency setting will disappear and I'll have no brow.  This brow is completely created in the "eyebrow" setting.  I have no brow "painted" onto the face map.
Boni
Boni ( ) posted Fri, 13 March 2015 at 5:22 PM
One reason there is an eyebrow is to be able to control the color and other aspects of the brow outside of the face map.  I've been working on expanding on this for quite a while now.
Boni
ElZagna ( ) posted Sun, 15 March 2015 at 12:13 AM
OK, just to make sure we're not talking past each other... You're aware, I take it, that Victoria comes with an eyebrow that by default is invisible but when made visible has a cast unlike the rest of her?
file_a2557a7b2e94197ff767970b67041697.jp
Boni ( ) posted Sun, 15 March 2015 at 7:42 AM
Yes, I am ... We all have a different level of knowledge of Poser and I see that you thought I was unaware of the upper brow.  I am intentionally using the upper brow as I feel it has versatility and has been under-used thus far.  I use a transparency map and color the diffuse to change the color of the brow rather than use a new brow on the face-map. I appreciate what you are saying and the effort you have put into to exemplify that.  Here is how I corrected my "blue" upper brow.
eyebrow in material room:
file_b73ce398c39f506af761d2277d853a92.jp
And here is the face-map with no brow.
file_5878a7ab84fb43402106c575658472fa.jp
As you can see there is no brow at all.
And finally using the same example you did, I made all BUT the brow invisible to show what the mat-room settings did.
file_9dcb88e0137649590b755372b040afad.jp
The upper brow has some great things you can do ... if you want to change the various attributes.  I kept it simple as per bagginsbill's suggestion.
Cheers
Boni
Boni
ElZagna ( ) posted Sun, 15 March 2015 at 9:32 AM
So I just looked at your gallery... "different level of knowledge of Poser" indeed! Nice stuff. You guys can carry on without me. ;)
Boni ( ) posted Sun, 15 March 2015 at 1:25 PM
Oh, sweety, not to worry.  Thank you and we'd rather "carry on" with you. Most people do NOT use the upper-brow.  Find it awkward and unnecessary.  I just like a challenge.  I've been in the community since '98.  Come on I'm sure your images are good too, share them.  I see you have no gallery images up.  I'd like to see your stuff. :)
Boni
