Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Zevo has an imperfection .Psd overlay MR over at Daz, there's also a ton of various .abr files for free on the web to modify, retouch, and paint skin. Also, look at reference and paint your own for that "hand made" feeling. Really, one of the easiest texturing things to achieve... just make sure to do all of your overlays on a new layer.
Edit_ don't forget, you can also create your own custom brushes and fill patterns.
Ok ... for your help I thought I'd show what I've done.
BEFORE: no alterations to the texture. Pure texture from MR.
AFTER: with brush texturing for tone and "blemish" as well as eye area treatment and transmapped brow and texture. Softening lip area etc.
This is just a beginning, but I wanted you to see that this is a great start and to thank you very much for getting me started on this!!
Boni
Boni
Boni, I hestitated to comment, because while i do see your effort, there is a lot missing. I see you have made some nice rosy cheekbones. But what i miss most of all, is depth and skin pores. Your specular settings are way too hight for this lightning. Eyelashes and brows too blurry. I see you painted over a merchant resource. That is a good practice. In my example i used photos on the model( projection mapping) and painted a lot of details on the skin. I tried to get skin as oily as yours.
You have to built up the pores. I would take with a colorpicker the darkest color and the lightest. Then i would make a skin color chart for that skin, in other words, i pick different colors between the lightest and darkest color. I paste every color from light to dark next to each other. ( you can do same for make up) If you use photoshop, ( i fetch from my 3d painting program to photoshop.. via a plugin) try to use noise brushes to add some difference in the skin, and some sharpness. What you can do is, alter the scatter brushes( i alter them, so you dont need to download skin brushes) You can also make your own. If you need more help i will try to explain more:)
Even though the example is still a wip skin, you can see bumps, irregular skin and even some scarring. I painted a lot on the skin to remove shine on the diffuse map. I didnt get it quite as oily as you but colored skin absorbes light differently. and is most of the time oilier.
I've also got info on this on FB and getting some help. My friends are showing me the same ideas you are ... and I must say you have done a lovely job here. I'd like to get a good texture going and eyelid textures ... alas, all I have are MRs and my 60 year old eye lids would look sad on a 30 year old model. (or 20 or well, you get the idea.) WithOUT that epiphany ... here is my latest. Again. Very little texturing, but I did add a character morph. and changed the base tone.
Boni
Also the limbs, eg legs is missing the veins overlay. It is ending by the torso map on the legs.
ZevO, thank you for the help ... silly me didn't see the pdf you added to the file. Here is my finished piece, what do you and the rest think?
"Waiting for Appointment"
Doesn't hurt to add cute kittens. Anyway. Fixed the vasularity, added props, jewelry and changed lighting ... here you go.
Boni
Much better. Can you show a closeup of an area so I can see the opacity levels?
That looks about right for that skin tone:) You can also erase areas if you wish to lesson the amount that is visible, or even erase with opacity to make certain areas more transparent than others.
I need sometipsand tuts on modifying skin MRs to look more like real skin with uneven tone, imperfection, blemishes and other individualizing features. Any advice would be greatly appreciated.
Boni
Boni
