Mon, Feb 17, 11:19 PM CST
Forum Moderators: RedPhantom
Subject: Can Poser tile a texture map?
fauve ( ) posted Wed, 03 October 2001 at 11:12 PM ยท edited Thu, 06 February 2025 at 11:30 PM
Another doofy question... is it possible to use a material in Poser that has a small bitmap as the texture which tiles and repeats to cover the whole surface? (Like wallpaper, carpeting, etc.) Thanks!
thgeisel ( ) posted Thu, 04 October 2001 at 12:48 AM
I think no!tried it myself ,got no solution.Did some tiling in a paitprogram
Kelderek ( ) posted Thu, 04 October 2001 at 1:10 AM
Poser can not do this for you. Tile the textures in e.g. Paintshop Pro and save it as a new picture before you apply it to the object in Poser.
ohman ( ) posted Thu, 04 October 2001 at 3:32 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=129657
You can not do this with a simple change of material properties. However if you modify the UV coordinates in the object to a greater range than (0,0)->(1,1) poser will tile the textures for you. This solution is only realistic for very simple objects like walls and such. Read more in the attached link ^^^ /Ohman
