Mon, Feb 17, 7:37 PM CST
Forum Moderators: RedPhantom
Subject: Displacement Map problem
arrowhead42 ( ) posted Tue, 21 July 2015 at 10:58 PM · edited Sat, 08 February 2025 at 9:00 PM
Hi everyone,
I'm working on texturing a superhero cowl, and using a displacement map to simulate a seam. But when I render the image, the line of the seam has something I'll call sparklies on it.... looks like scattered pixels that are the color of the flesh texture beneath the cowl. See the image attached here. You may have to look close to see them, but they're there. Can anyone explain what they are, or how to make them go away?
Thanks -
file_a0a080f42e6f13b3a2df133f073095dd.jp
Here's the link to my freebies:   https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
Boni ( ) posted Tue, 21 July 2015 at 11:09 PM
How is the map plugged in? Can you show us your material room settings? Maybe a screen shot.
Boni
Boni
arrowhead42 ( ) posted Tue, 21 July 2015 at 11:28 PM
Sure.... here it is. Note that the setting is .1, but it even did it at the default setting of .0833
file_bf8229696f7a3bb4700cfddef19fa23f.jp
Glitterati3D ( ) posted Tue, 21 July 2015 at 11:33 PM
My  guess is that your displacement is set too high.  Turn it down a little at a time and test until it is set to stop causing the distortion.
You can set it higher if you use bump instead of displacement.
bagginsbill ( ) posted Wed, 22 July 2015 at 6:50 AM
You want a displacement of over an inch on what now?
Miss Nancy ( ) posted Wed, 22 July 2015 at 10:36 AM
also, uncheck refl lite mult.
maybe is unchecked by default (or channel deleted) in P11.
Boni ( ) posted Wed, 22 July 2015 at 1:04 PM
I may be off here, but challenging  a lower displacement with a higher bump might do the trick. Gurus, a techie expert reason would be a better answer.lol.
Boni
EldritchCellar ( ) posted Wed, 22 July 2015 at 2:12 PM · edited Wed, 22 July 2015 at 2:14 PM
Min shading rate? Displacement bounds? Map too pixelated? Not running through subtract node? Could be any number of things. Bagginsbill is here so you're in capable hands.
Taren421 ( ) posted Thu, 23 July 2015 at 9:15 PM
Also, try changing the filtering on the displacement to "crisp" or "none".
Poser Pro 2012 SR3 on Win10 x64 w/Reality.
Poser Display Units = inches.
Miss Nancy ( ) posted Fri, 24 July 2015 at 12:19 PM
OP should try low bump - may speed it up.  wouldn't use both bump and displ.
 use tex filtering when tex have repetitive patterns, but with lines like that you would use "none", gamma=1 and make sure lines are anti-aliased, not jaggies.
bagginsbill ( ) posted Fri, 24 July 2015 at 12:32 PM
My point is it's a thin line raised up from the surface over an inch. I can't imagine that's what you want. If it's a low ridge, then make it a low displacement and the holes will go away.
