Thu, Nov 28, 12:38 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Multiple name instances of a texture file after import to Blender
RobynsVeil ( ) posted Sat, 08 August 2015 at 4:58 AM · edited Thu, 28 November 2024 at 12:30 PM
Has anyone ever encountered this?
file_07e1cd7dca89a1678042477183b7ac3f.jpI'm trying to render scenes created in Poser, in Blender, largely because I can add caustics but also because the lighting is more sophisticated and the support for stuff like grass is better. But this: this is annoying. Almost never does the actual xxx.png or xxx.jpg work: it's always the xxx.jpg.004 that does. And getting rid of the bogus references... a royal pain.
Does anyone know of a script or work-around? I spend seriously HOURS cleaning this nonsense up.
Metaphor of Chooks
Lobo3433 ( ) posted Sat, 08 August 2015 at 3:37 PM
Forum Moderator
Hi Robyn
Are you using the Mcasual's script to do the import form Poser into Blender? I think and can be mistaken there is a new beta for the script that might address this but am not 100% sure
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
RobynsVeil ( ) posted Fri, 14 August 2015 at 9:18 AM · edited Fri, 14 August 2015 at 9:19 AM
Sorry to be so long getting back to you, Lobo.
In answer to your question: no, I do the following:
1] I set up a folder - I call mine 'Export'
2] bring up my scene in Poser, pose my figure(s) and stuff, get everything render-ready
3] under 'Scripts', go to 'Utility' and select 'Collect Scene Inventory'
4] select 'Copy all to folder'
5] navigate to my 'Export' folder - type in the name of my scene, which is what it is asking for. It'll save it as a new .PZ3. It will also save all textures files (images) to that folder as well as all OBJs, even stuff I don't use in Blender. Important to note is this: it will save all your OBJs as separate entities, which - for me at least - makes it easier to keep things apart so I can move them around a bit. Some folk prefer to also export the entire scene as one OBJ.
6] in that newly created Export folder, move all like with like: OBJs into an OBJs folder, JPGs and PNGs into a textures folder, and other Poser stuff into a Poser folder. I even put OBZs and shoulder and groin fix OBJs into that Poser folder, since they're not needed in Blender.
7] I have a special /Blender/Projects folder... so I move this export folder there and rename it to my scene name
8] open Blender, and save my blank scene as SceneName01.blend - for example, Ballet01.blend ... I keep versions even more than Blender does, so it is easy to go to a previous version if I stuff something up. Incrementing to the next version is dead-easy: you do a SaveAs, click the plus sign (+) next to the name, and click Save. So much of Blender is like this, one wishes other software was this clever.
9] Import OBJs into a Blender scene: Import -> Wavefront (.obj) ... in the ensuing dialogue:
A) untick 'Smooth Groups' and 'Lines'
B) select Keep Vert Order (for re-importing back into Poser)
C) tick 'Poly Groups'
D) select OBJ and click Import
I know: looks tedious but I have full control over what happens. Now, some mesh has multiple material zones: each one that uses the same jpg is assigned a variant name of that jpg.
I DID finally find a way to get around the ensuing mess in the dropdowns: a simple Python script which goes something like this:
import bpy
import os.path
for image in bpy.data.images:
__if not image.pixels:
____image.user_clear()
Just replace the '_' underscores with spaces, save in a pure text editor as clearUnusedImg.py to somewhere. This seems to work, clearing out all references not only to unused texture files, but also to those dreaded img.jpg.001 / img.jpg.002 / img.jpg.003 / img.jpg.xxx / img.jpg.999.
Metaphor of Chooks
