Yes, this is a Poser Rendering.
2 lights from windows 1 IBL 1 BB Sphere
Rendered with Firefly.
"artifacts in the shadows" Yes, i think that increasing render settings may be there is a way to fix them. I hope in a better GPU Render Engine in next Poser 2015
Poser Pro 2014 SR 1 on Windows 7 64
bit
I use IDL, Gamma Correction and EZSkin for all
final renders.
Kazam561
follow me.
BB Sphere has HSV value Set to 84 IBL light is set to 84
try a render on medium resolution, you'll see a lot of artifacts in the shadows.
To fix them look at Firefly IDL setting (bounces, Cache ecc.) , do your test step by step. Play with color light too.
I hope will help
bit
final renders.
it looks great! there are some IC artifacts in ceiling lampshades. eliminate those by not using IC
decrease IDL intensity to 0.8
increase IDL bounces to 16
may be slow, but will look even less like poser render.
PP2016 no use GPU renderer but handles IDL bounces better, w/no IC artifacts. BB rendered similar scene in PP2016. time ~3-5 hrs IIRC.
I have to say, to me, it's not the lighting or render quality which gives it away as a "Poser" rendering. It's the models. No offense to whomever made those props, but in this realistic light, with these materials, they do look a little "soft", and fake. Almost like a dollhouse furniture. I'm sure at a distance, with characters in the scene, they would serve their purpose well, but for realism in a scene like this, I would be looking for more detailed props.
I also think the floor is a little too glossy for wood (if it's supposed to be wood). Even the highest polished wood floors would have some fresnel reflectivity, and appear more blurry, with some bump involved. All the other materials look ok, and the lighting is good. I think using more realistic models would really make this a great render.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Is this a Poser rendering ?
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
