New Poser Users Help F.A.Q (Last Updated: 2025 Jan 21 1:38 pm)
So that these will show up in a search for Snarleygribbley, I am listing all of his scripts:
Debut Render - Adds IDL rendering capability to Poser Debut 10
EZCompile - Compiles python py files tio pyc files
EZIcons - Another programmer's utility - used to make the Python code needed to embed graphics (icons) into a Python script so that it does not need to reference any external files.
EZMat - Extension to the Poser 10 Materials room. Simplifies and extends the operations there.
EZMetals - A GREAT set of realistic metal shaders
EZSkin2 - Fixes skin materials so the render correctly using Poser's advanced rendering options.
Gammafixer - Fixes Gamma values for Poser to use Gamma Correction. Appears to be superseded by Scene fixer.
KeepFocus - Keeps Poser from changing focus during morph brush use.
MatHelper - A Mat room utility. Superseded by EZMat.
Particles3+ - Adds particle functionality to Poser. Now works with Poser 10.
PNGMaker - A vendor utility to make make PNG thumbnails for all the Pose files in a folder. It applies each pose file in turn and creates a thumbnail.
Pos2Lux - like Reality, this script transfers a Poser scene to Luxrender.
Proplight - Saves a composite prop consisting of a Light object and Prop object. Parent the Light to a Prop and use Proplight to save a .pp2 file combining them.
Propswap - An addon that lets you easily replace the currently selected Prop with a new one from the library, such that the new one takes the same position and orientation of the one it is replacing.
Scenefixer - Fixes all of the values in a Poser scene to take advantage of Gamma Correction in rendering.
SnowMachine - Will add a couple of inches of snow to any Poser scene.
Subdivider - Much like the subdivision feature in PP2014GD, this adds polygons to a model to enhance it's realism.
Several thuings that are almost required to make Poser work right have recently disappeared from the net... most notably Snarleygribbley's scripts. With his permission, I have posted a number of these userful "orphans" at: http://orphans.basicwiz.com
Everything there is free.
Hope this helps.
