Thu, Jan 30, 7:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 7:06 pm)
Subject: When I inject this body morph into V4, V4's head becomes huge.
Grimhilda ( ) posted Fri, 25 September 2015 at 4:15 PM ยท edited Thu, 30 January 2025 at 3:23 PM
Hi everyone,
(The following is a copy of a question I put to the Poser New User forum yesterday. I mean no offence asking here also but I'm hoping the question might get more views)
I'm still pretty much a novice with Poser but like the program very much and have just bought Pro 2014.
Because I also use Carrara, I'm trying to get the best from both by building up some content for the V4 /M4 figures which I haven't really used much. I have V4 and the morphs ++. I bought S4 elite and have just bought MRL Melissa SU (https://www.renderosity.com/mod/bcs/mrl-melissa-su/86966).
I've been loading V4 and then the Melissa body INJ (from the pose library). The head becomes hugely out of proportion. But when I inject the Melissa Head morph, only the face changes. I've tried this with and without the S4 Elite morphs and the V4 ++ morphs but can't find a way to reduce the size of the giant head.
Do I need to buy something else? I noticed that there is a V4 elite package but hope I wont need to buy it. (Although, if it is something that gets incorporated into lots of other characters then I'd be willing to.)
Thanks for any advice.
Grimhilda ( ) posted Fri, 25 September 2015 at 4:39 PM
It's OK now.
I searched through the Morphs ++ in the Pose library and double-clicked on 'Head Size'. The morph dial then appeared in the Parameters window.
I'm still a bit puzzled as to why that dial didn't appear after I had loaded Morphs ++.
I'll update the other thread for beginners.
hborre ( ) posted Fri, 25 September 2015 at 6:07 PM
Online Now!
I posted a response in the other thread.
quietrob ( ) posted Fri, 25 September 2015 at 9:37 PM
I had this happen to me as well. The solution was to reinitialize V4. There should be a batch file that you run once and then forget about it. Still, it seems you have your solution.
hborre ( ) posted Sat, 26 September 2015 at 7:21 AM
Online Now!
That was my assessment also which was posted at the other thread. Reinitialize to correct the problem because it will crop up again unexpectedly. Go to Runtime>Libraries>iDAZ, and double-click DZCreateExPFiles-V4.bat. This should take of the issue. And this must be done every time a new DAZ morph package is installed.
Grimhilda ( ) posted Sat, 26 September 2015 at 5:38 PM
Thanks so much, quietrob & hborre.
The solution you've both explained would never have been one I'd have discovered for myself.
Best regards.
