Wed, Jan 8, 1:43 AM CST
Subject: Help! I'm Dumb...Export Object NOT WORKING
Darth_Logice ( ) posted Sun, 28 November 1999 at 12:31 AM · edited Mon, 06 January 2025 at 10:19 PM
Why is this not working? I loaded a couch into bryce, selected it and NOTHING else, and went to export it to OBJ (OR anything would be nice at this point) and the option is not selectable. However, I somehow managed this before. What's going on? -Darth_Logice
Quikp51 ( ) posted Sun, 28 November 1999 at 3:58 AM
Bryce won't export anything beyond basic 2D lattice. Someone here mentioned a trick where if you select the object and theres an "E" option to click , click it and while the meshsmooth window is OPEN goto your export option and you can export what you want. I hear this will only work if you have an "E" option to click. Hope this helps.
KenS ( ) posted Sun, 28 November 1999 at 5:36 AM
That's true, If you can select "E" Edit Mesh/Smooth Object, then do so. When that window appears hit CTRL+D and you will get a Save As.. Dialogue.
