Sat, Feb 8, 10:52 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 08 4:39 am)
Subject: add clothes and combine it with figure
sayangske ( ) posted Wed, 11 November 2015 at 7:40 AM ยท edited Sun, 02 February 2025 at 12:07 AM
hallo, Now I have a figure (Dawn) also clothes and shoes who i put on the figure. I try to make moves with all these things but the clothes don't move with the figure. Is it possible to make a figure who can move together with the clothes, shoes and so an?
sayangske
hborre ( ) posted Wed, 11 November 2015 at 8:10 AM
If the clothing is conforming, then you will need to conform the items to Dawn. Two ways to conform clothing to figure. If you own the most recent Poser versions, select the clothing in the Library and drag & drop onto the figure; this is one way to conform clothing automatically. The second way, select the clothing item in your preview tab, select figure from the taskbar menu and select conform to... from the pull down. A window will appear with figure options, select the figure you want the clothing to conform to and click ok. This should do it unless the clothing is dynamic, in which case, this is an entirely different process.
Always state which Poser version you are using to facilitate giving you the correct information. Different versions may lack some features outlined above. It will also help if you include which specific content you are attempting to incorporate into the scene. There are different approaches to working with specific content and getting the best results.
donnena ( ) posted Wed, 11 November 2015 at 8:15 AM
two options! You can load everything, then select the clothing and then choose Figure > Conform to and then choose DAWN's Body from the drop down list.
Or you can load Dawn and Click on her to be sure she's selected. Then with your mouse, grab the item you want her to wear and drop it on top of her. Poser will sweetly pop up a box saying Conforming to Dawn. You don't have to select the part of her the clothing fits... I usually click on a finger, even when adding boots.
Now this only works if you're clothing is coming from from the Character Section of the library. If they're located in Props they are dynamic clothing and will need to be fitted Via the Cloth room. I have instructions for that if you need them.
Andy!
Andy!
sayangske ( ) posted Wed, 11 November 2015 at 10:25 AM
I work with Poser pro 2014 , My problem is not to add the clothes, because i do that with grab and drop.The thing is that when I move a leg, the trouser stay on the same place.I want to move the figure so that hair, clothes and shoes follow the body. I think it must be possible to make a standalone figure, complete with clohes, but I don't know how to do this
sayangske
donnena ( ) posted Wed, 11 November 2015 at 11:57 AM
Please try the first method, then.
conforming clothing will follow the figure quite nicely.
Andy!
sayangske ( ) posted Thu, 12 November 2015 at 3:04 AM
Thank you very much.It works with conform to..... I'am sorry that I not could do it after the first mails, but i'am an newby that somethimes need help and without your support i coulnd not work with Poser. So thanks again for your support.
Sayangske
donnena ( ) posted Thu, 12 November 2015 at 7:54 AM
If you select the target figure before you drag and drop, the clothing should Auto conform! Good luck and enjoy Poser!!
Andy!
hborre ( ) posted Thu, 12 November 2015 at 8:40 AM
For drag & drop to work properly, select whatever content you desire to dress the figure and drag it to the figure, not the stage of your scene. There is no need to select the actor before attempting this procedure. The selection is automatic.
sayangske ( ) posted Mon, 16 November 2015 at 8:07 AM
I tried it all and everything works. Thanks again for the help that everybody gave me.
