Sun, Nov 24, 10:43 PM CST
Subject: Poser 11 SR1 out now
basicwiz ( ) posted Mon, 07 December 2015 at 7:06 PM · edited Sun, 24 November 2024 at 8:34 PM
Check your Smith Micro Download Manager
ssgbryan ( ) posted Tue, 08 December 2015 at 12:25 AM
Thanks for the info.
vitachick ( ) posted Tue, 08 December 2015 at 4:57 AM
Library is much better now.Faster.Next I do hope it can be shown as external image. Feel being docked the way it is too much work space is being taken up.
Win10  Poser 2014/Poser 11 Daz3D
chaecuna ( ) posted Tue, 08 December 2015 at 5:48 AM
Nerd3D promised faster updates and he is keeping his word. Rare quality in today's business world.
pigfish9 ( ) posted Tue, 08 December 2015 at 10:22 AM
I bought physical copy. Any idea how to get the update? The link to updates in Poser Pro 11 points to updates for PP2014. I haven't received any emails from Smithmicro either.
Jules53757 ( ) posted Tue, 08 December 2015 at 11:05 AM
vitachick posted at 6:00PM Tue, 08 December 2015 - #4243121
You can undock (floating) the library by clicking on the little triangle above the magnifier. Then you can change the size of the library to your needs even nearly full screen and then youl find in the upper right corner some "Books", clicking on them shows or hides the library.
Ulli
kerwin ( ) posted Tue, 08 December 2015 at 11:41 AM · edited Tue, 08 December 2015 at 11:41 AM
I think the download manager is the same. Get it here: http://my.smithmicro.com/poser-pro-2014-updates.html
(There may be a copy of the download manager on the disk that came with the physical shipment.)
After you have the download manager on your system, start it and enter your Serial Number. It should validate your number with SM's servers and you'll want to click on the update's tab.
HTH,
-K
pigfish9 ( ) posted Tue, 08 December 2015 at 4:01 PM
kerwin posted at 4:01PM Tue, 08 December 2015 - #4243195
HTH,
-K
THANK YOU!
nerd ( ) posted Tue, 08 December 2015 at 5:12 PM · edited Tue, 08 December 2015 at 5:14 PM
Forum Moderator
Poser 11's first service release is ready for download. We've fixed over 30 of your top bugs. If you have Download Manager still installed you can download your updates now. If not you can get the Download Manager here: http://my.smithmicro.com/poser-11-updates.html
Bug Fixes in SR1:
General
• Poser now launches on Windows 8. This OS version remains unsupported. Please update to Windows 8.1.
• Library and Log palette toggle icons are now easier to click.
• Enabled Facebook upload for rendered images (Windows only).
• Fixed case where closing document while viewing it with a non-default camera would cause instability.
• Fixed case where deleting a non-default camera would cause instability.
• Added a dependency between Center of Mass actor and figure. Center of Mass prop can no longer be deleted, preventing instability.
• Now automatically enabling Body actor when loading figure with skinning method set to Poser Unimesh.
• Updated Wardrobe Wizard.
Content Library
• Item List panel: Enabled Drag and Drop.
• Item List panel: Sped up library item loading from highly populated folders.
• Now properly omitting folder thumbnail display when no thumbnail is available (Internet Explorer 9 only).
• Better messaging for empty search results when indexing.
• Added support for conforming hair with CR2/CRZ file extensions in Hair category.
• Now preserving divider position between Tree and Item List view panels more reliably.
• Refresh item icon now rotates while refresh is in progress.
• Improved Add to Favorites dialog layout.
Material Room
• Fixed a problem with scene preview showing incorrectly after a Copy and Paste in Advanced view.
• Copy and Paste now honors the selected render engine when pasting selections including root nodes.
• Fixed problems where the FireFly root or SuperFly root was not 0th in the Node list.
• Compound nodes: Improved internal wiring robustness.
• Enabled use of more than one Cycles ImageTexture node at one time.
Preview Rendering
• Fixed excessive transparency when layered materials are used.
Final Rendering
• Saving and loading a turned off light now preserves Cast Shadow flag.
• SuperFly: Improved handling of dark highlights on PoserSurface and PhysicalSurface in branched path tracing.
• SuperFly: Now verifying that light shaders are up to date when rendering.
• SuperFly: Now interpreting material node vector inputs as linear.
• SuperFly: Improved handling of transparency in path tracing on PoserSurface and PhysicalSurface.
Figure Creation
• Enabled magnet zone weight painting on Poser Unimesh skinned figures.
• Fixed case where deleting a Full Body Morph while Dependency Editor was enabled would cause instability.
Import/Export
• OBJ Export: Corrected "As Morph Target" export path. Now properly using the untransformed vertices combined with active morph and magnet deforms to allow for eventual re-import as morph target in local space.
• GoZ: Fixed case where "." in the object name would cause instability (Poser Pro only).
• Fixed case where loading an MP3 misrepresenting its sample count would cause instability (OS X only).
simontemplar ( ) posted Wed, 09 December 2015 at 12:10 PM
Still no Paul?
