Sun, Jan 5, 7:07 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Render every n:th frame of animation
Tiny ( ) posted Wed, 23 December 2015 at 8:13 AM · edited Fri, 03 January 2025 at 8:19 AM
The script I have is built upon Ockhams CamCircle script. It rotates the cam and renders every frame of an animation in 16 directions (or other selected amount of directions). How would I go about to add the choice of "render n:th frame" of an animation within the above mentioned script? For example, I have an animation with 39 frames and would like to render every 3rd frame of it. I can do this within Poser itself of course, one direction at a time but figured I try to automate it as much as possible. :) Here is the main action part of the script:
CamRot = scene.Actor(CamName).Parameter("yOrbit") for F in range(scene.NumFrames()): for Step in range(int(Steps)): scene.SetFrame(F) CamRot.SetValue(Step * 360.0 / Steps) scene.Render() LastName = 'Angle%3.2f%1d.png' % (Step,F) scene.SaveImage("png",os.path.realpath('E:/')+'Renders/'+(LastName)) poser.CloseDocument(1) return 1 # All OK
Sorry, I don't know how to prevent the text bunching up like that.
bagginsbill ( ) posted Wed, 23 December 2015 at 8:17 AM
Change
to
for F in range(0, scene.NumFrames(), 3):
bagginsbill ( ) posted Wed, 23 December 2015 at 8:19 AM · edited Wed, 23 December 2015 at 8:20 AM
Note the parameters to the range function are
initialvalue (I used 0), limit, step (I used 3)
When you only say one argument then it assumes initialValue = 0 and step = 1
Tiny ( ) posted Wed, 23 December 2015 at 9:24 AM
Thank you bagginsbill! Hugs
