New Poser Users Help F.A.Q (Last Updated: 2024 Dec 23 11:36 am)
This modeling program has been out for a very long time, vendor is Markdc sold through DAZ3D. You will need to contact DAZ for your registration and serial number which you should have received by email. I don't think anyone uses that app anymore, it's been basically replaced by Hexagon, Blender, Wings3d, etc, all programs which can be found for free.
If the program has out for a while,why does`nt he (mark) remove them.It is very misleading this way.Wasted my money. I have Blender on my pc so I think I will try this and see what I can do with it. Thank you anyway for your answer. May be I can try to get my money back.
Have a nice sunday. Grtz Sonja
Hello Sonja68
Just as an FYI when installing this software on a Windows 7, 8 and I think now Windows 10 you need to install it as Admin and the first time you run the application must run as Admin so you can enter the serial key with your userkeyname with a 3 dgit number and then the serial number. I own this product and will say that Blender is greater tool and has many more features than Pegasus Modeler will ever have. Wings 3D is also superior to it regretfully Hexagon as not had a update in over 7 years.
Lobo3433
Hello Sonjas68
I edited your last post since you posted your serial key and did not want someone else to attempt to use it if they came across this post. The only other think I can suggest at this point is to contact Daz support since you made the purchase with them. And if it was done with in the last 30 days maybe you can get a refund for your purchase
Lobo3433
Hello Sonjas68
This might help: http://www.3dutils.com/enter-key.htm
I had a similar problem and it was because I was entering the user name wrongly. If you cut and paste user name and licence exactly as shown in the above link all should be well. Re Pegasus and Hexagon. Hexagon is free, and powerful. But Pegasus, at least in my experience, does offer something a little bit different. I've had success with both... and some frustrations with both, however the frustrations are entirely due to inexperience which can only be cured with time, patience and practice.
Aside from getting DAZ to refund you at this point and if you bought it within their 30 day refund limit they will refund it.
I would check the last numbers of the serial number. I picked Poser 11 not too long go and after a month of being run around like a crazed cat chasing its tale by their tech support I accidentally remembered something I had a problem with in the past and typed an extra blank space after the last number of the SR# and voila!
ENTERED!
Just a thought...but I would get a darn refund and pick up something more modern to use.
Hello
I just downloaded Pegasus modeling 3.0 on my pc,and now I need a key number. I suppose it means serial number and I found that in my acount. Only it says it's the wrong serial number so it does`nt work How do I get the right number so I can start the program? Hope anyone can help me.
Grtz Sonja
