Mon, Feb 17, 7:11 PM CST
Forum Moderators: RedPhantom
Subject: Three shades of SuperFly skin
bantha ( ) posted Sun, 24 January 2016 at 9:11 AM · edited Mon, 17 February 2025 at 7:10 PM
Hello,
here are three images, with three different SuperFly Skin Shaders. Which one do you like most, or least, and why?
-"Amazing Grace" Hopper
SpookieLilOne ( ) posted Sun, 24 January 2016 at 9:35 AM
I personally like the second one. I am partial to pale skin with rosy pink tones.
*~*Jamie*~*
SpookieLilOne's Store
SpookieLilOne's FreeStuff
SpookieLilOne's Gallery
"Life is just a dream on the way to death." ~The Crow: City of Angels
A_Sunbeam ( ) posted Sun, 24 January 2016 at 9:41 AM
2nd one.
Jules53757 ( ) posted Sun, 24 January 2016 at 9:57 AM
2nd one looks better
Ulli
bantha ( ) posted Sun, 24 January 2016 at 10:03 AM · edited Sun, 24 January 2016 at 10:05 AM
Here are the same three skin shaders, with a different light. Same order.
Jules53757 ( ) posted Sun, 24 January 2016 at 10:23 AM
Evennow the 2nd looks more realitic
Ulli
SpookieLilOne ( ) posted Sun, 24 January 2016 at 10:27 AM
Second is still my choice
*~*Jamie*~*
bagginsbill ( ) posted Sun, 24 January 2016 at 10:53 AM
2nd but with one major problem needing correction. It has too much Fresnel effect. Rough surface Fresnel means that the amount of reflection at grazing angles is much reduced from smooth surface Fresnel. I have noticed quite a few SuperFly skin shaders with this problem. It accidentally gives the illusion that the surface is velvet.
bagginsbill ( ) posted Sun, 24 January 2016 at 11:04 AM · edited Sun, 24 January 2016 at 11:04 AM
The outdoor comparison would be easier if #1 and #3 were not so overexposed. I'd either turn down the lighting or the shader. Being overexposed turns the skin more yellow, with a pink halo around the hot spots.
bantha ( ) posted Sun, 24 January 2016 at 11:09 AM · edited Sun, 24 January 2016 at 11:19 AM
I've changed the shaders 1 and 3 a little bit, so that the image is about the same skin tone. No changes to shader 2 were made, I've seen the last comment too late for that. Different light again. Still Shader 2 for everyone? Render-3-1.pngRender-3-2.pngRender-3-3.png
bantha ( ) posted Sun, 24 January 2016 at 11:11 AM
bagginsbill posted at 11:10AM Sun, 24 January 2016 - #4251011
Would that need a new render or could i change the lighting by exporting an exr and turn the lighting down in Photoshop?
bagginsbill ( ) posted Sun, 24 January 2016 at 11:13 AM · edited Sun, 24 January 2016 at 11:15 AM
exr with post exposure control would work fine. (I think)
Come to think of it, I've not tried HDR exports from SuperFly. I don't know if its buffer is HDR or not.
We had to turn this on as a rendering option for FireFly because the original FireFly buffer was not HDR. So you had to tell it you wanted that effort applied.
bantha ( ) posted Sun, 24 January 2016 at 11:22 AM · edited Sun, 24 January 2016 at 11:24 AM
Of course, the background is much darker. But it seems that SuperFly does HDR per default.
bantha ( ) posted Sun, 24 January 2016 at 11:27 AM
Hard to compare, at least for me. The background makes the comparison difficult. I will render the images again in a couple of hours, no time right now.
I will tell which shader is which later.
