Community Center F.A.Q (Last Updated: 2025 Jan 10 12:32 am)
Does this happen right after you post it or 15 minutes later? The reason I ask is we have a rule that after 15-minutes, you can no longer edit your post, so maybe that's it? I just tested it out and it worked fine. Let us know and thanks!
Hope Kumor
Editor-in-chief of Renderosity Magazine
What do you mean by this, "should there be a Yellow warning in the top of the post if it applies...." ? Do you mind explaining a bit further, please??
Hope Kumor
Its red, so i got that wrong :D
I mean that "Content advisory - Nudity advisory" which is written with red in the top of the post. Does that make sense?
I know what you mean. By, if it's nudity, violence or language, you simply check this below: (Not sure if I answered your question/figured out the issue....)
Hope Kumor
Okay - that's a HUGE problem. I just brought this to the programmers attention. Once it has been fixed, I will let you know. So sorry about this!
Hope Kumor
Hi everyone-
I wanted to make this thread before I brought the remaining issues to the programmers!
This is for BUGS/ISSUES only. Please don't use this as a thread to complain about us. Again, we're doing our best to fix the issues/problems at hand. I know about your suggestions for the site search option, so please skip over that one.
For example, please note if you're having problems with:
Thanks so much!
Hope Kumor
