I actually use a script instead of the focus guide, which can sometimes be difficult to position correctly. The script tells you the distance between the current camera and any selected actor, so you can set the correct focus distance without using the guide. (Python Scripts window --> Render / IO --> Calc DoF Focal Distance).
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Not saying this is it, but in the past, I had iterations of my graphics driver that borked the focus distance control.
"Suddenly, the "crosshairs" of the camera aren't showing up" sounds a lot like "suddenly I let Windows update my display driver".
Try switching your preview to SreeD and if the crosshairs show fine, you have a video driver problem.
I've been trying to play with the DOF settings in PP2014 lately and it's worked great... until today. Suddenly, the "crosshairs" of the camera aren't showing up when I try and adjust the Focal Distance of the camera. Depth of Field is turned on in the Render settings, I'm looking at the camera settings for the actual camera I'm using, but no matter how much I adjust the Focal Distance, the crosshairs aren't showing up so I have no idea where the camera is actually focusing. I've tried several different cameras... closed and re-opened the program and file... but nothing. Any suggestions?
