Sat, Jan 25, 7:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Subject: 'Conform to Scaling' on for "V4Height Dial"
vxg139 ( ) posted Sun, 08 May 2016 at 11:09 AM · edited Sat, 18 January 2025 at 10:21 PM
Hi,
Can I please ask our Poser experts to explain where the option of 'Conform to Scaling' resides in PP-2014? I just purchased "Victoria 4 Height Dial" and from the product description, it seems that by turning this option on, clothing will scale to fit the altered size of V4.
thank you
vxg139
Lyrra ( ) posted Sun, 08 May 2016 at 12:18 PM
Copied from the readme:
You MUST have the scale dials visible to use this product. Either use a utility pose to make the dials visible or turn on View Hidden Parameters.
On the right side of the Parameters window is an arrow. Click on this and turn on View Hidden Parameters near the bottom of the list.
NOTE - most clothing is not saved with 'Conform to Scaling' on. Make certain to turn that on so the clothing will scale to fit. Select Body of the clothing item and go to the Properties tab. Turn on the selection boxes for Include morphs, and Include scaling
Clothing with handles may need the Hip scaling copied manually to the handles. Not all conforming clothing is made the same way, so some adjustments may be needed.
LM
vxg139 ( ) posted Sun, 08 May 2016 at 2:37 PM · edited Sun, 08 May 2016 at 2:37 PM
Great thanks....It all makes sense now....
vxg139
estherau ( ) posted Mon, 09 May 2016 at 6:52 PM
so when you go to the clothing properties you will see the right dial to check. let us know if you can't find it.
MY ONLINE COMIC IS NOW LIVE
