Tue, Dec 24, 11:32 PM CST
Subject: How to get a transparent background in export render Poser 11
AetherDream ( ) posted Sun, 22 May 2016 at 8:36 PM · edited Tue, 24 December 2024 at 11:16 PM
I have always been able to export a png with a transparent background from Poser. For some reason, I have not been able to figure out how to do this in Poser 11. Does anyone know how to do that?
"People who attempt define what art is or is not, are not artists"---Luminescence
Boni ( ) posted Sun, 22 May 2016 at 10:39 PM
All you need to do is make the GROUND prop invisible. It is actually a modified sky dome with ground plain (called the construct). Once you do that the background is like before P11, and will export "empty" in the background.
Boni
AetherDream ( ) posted Sun, 22 May 2016 at 11:01 PM
Duh!! I feel so stupid. I have had Poser 11 Pro since it came out but I have been very slow to move from PP14 which I love mainly because I encountered this issue and could not figure out what I was doing wrong or if the program itself had some issues that needed tweaking. I picked it back up to fiddle around with it again today after installing updates thinking that it was some unresolved issue when it first hit the market. I am glad I posted this question so that I would figure out just how low my IQ is LOL! Thank you so much for your answer! Your fix worked perfectly.
Boni ( ) posted Mon, 23 May 2016 at 7:01 AM
No reason to feel silly. If you are unaware of new features things can look ... "wrong". Just glad I could help.
Boni
3Dpixi ( ) posted Mon, 23 May 2016 at 5:14 PM
Great to know .. couldn't find it either .. 😃
Do you also happen to know how to render over black background [like the option PP2014 has] Boni ..??.. It avoids that irritating glow around a render so you can blend in to a background way better ,,
Boni ( ) posted Mon, 23 May 2016 at 7:07 PM · edited Mon, 23 May 2016 at 7:10 PM
Not sure if this will work for you ... but with the construct in the material library there is a "blackout" setting. I'm guessing here, but this could do the effect you are looking for. Hmmm. Since it uses a construct setting I'm thinking this won't work for your purposes BUT I believe there is a process to do this. I just don't know what it is. It's late here, so give me some time, I think I did read somewhere how you can blend colors from a background image to the foreground figures. I will look into this tomorrow.
Boni
3Dpixi ( ) posted Mon, 23 May 2016 at 11:54 PM
Thanx for thinking with me Boni .. 😃 .. Always known where to find in previous Poser versions but in Superfly it does not show up
Found another thread about this .. [sorry .. just saw] .. Popped my question there as well
https://www.renderosity.com/mod/forumpro/?thread_id=2900563&page_number=1#msg4270272
scottl ( ) posted Fri, 16 February 2018 at 8:08 PM
Forgive me for being terribly dense. Am also trying to render out with a transparent background. I searched for the above fix but find no ground plane to fix? What am I missing? Thx
seachnasaigh ( ) posted Sat, 17 February 2018 at 2:17 AM · edited Sat, 17 February 2018 at 2:23 AM
If rendering in Firefly, then you can simply hide the construct (It appears as "ground" in the hierarchy list, but it's a fully enclosed ground+skydome).
If rendering in Superfly, you need to apply a holdout node to the construct.
So, you can render just the dolly in Superfly:
That gives you a clean (no background, no extraction fringe) PNG object on transparent background.
seachnasaigh ( ) posted Sat, 17 February 2018 at 3:03 AM · edited Sat, 17 February 2018 at 3:12 AM
DIGIpixel posted at 2:54AM Sat, 17 February 2018 - #4270233
If rendering in Firefly, hide the construct ("ground"), then render over current background shader and export image as a PNG. That should give you a PNG object on transparent background with no need to extract the doll in PhotoShop, hence no fringe/glow. No need to do anything to the background shader if you export image as PNG. That is found in the Firefly render options:
If curious about the "background" shader, enter the material room and open the object dropdown; select background.
But, again, you can ignore the background shader if you export image as PNG.
seachnasaigh ( ) posted Sat, 17 February 2018 at 3:07 AM · edited Sat, 17 February 2018 at 3:08 AM
I should clarify that for Superfly, the construct should remain "visible" (not hidden), but apply the holdout material shown above to both the ground and the background (sky) material zones of the construct. Export render as PNG.
seachnasaigh ( ) posted Sat, 17 February 2018 at 3:25 AM
This is an example of why I recommend exporting a PNG raster object, rather than trying to extract the doll in PhotoShop. Can you imagine trying to extract the hologram from this render?
But, if I hide the spaceship interior prop, and apply holdout to the construct, then render (Superfly, in this case):
The materials for holograms (one for Firefly, one for Superfly) are in this Ghost, wireframe, and Cortana material pack, if you want to play with that.
anniemation ( ) posted Tue, 31 May 2022 at 10:51 PM
seachnasaigh,
I tried your method but still can't get a transparent background.  Not sure what I'm doing wrong.  Export image>png right?  I get black background in Photoshop.
Y-Phil ( ) posted Wed, 01 June 2022 at 8:12 AM
anniemation posted at 10:51 PM Tue, 31 May 2022 - #4439381
seachnasaigh,
For superfly: don't forget:
1. to make Poser's default construct visible
2. to put this mat setting on both parts:
And (snapshot from photoshop)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
MeInOhio ( ) posted Wed, 01 June 2022 at 6:37 PM
I usually hide the ground. Can't see where the lights are if it is visible. Then when I render in Superfly, I check the option "Transparent background". I think is the ground is visible, then you won't have a transparent background even if you check transparent background. BTW, I'm using Poser 12, but I assume it's the same in Poser 11.
Y-Phil ( ) posted Thu, 02 June 2022 at 2:04 AM
MeInOhio posted at 6:37 PM Wed, 1 June 2022 - #4439436
In fact, Superfly's "Transparent Background" option is a Poser12 thing, it doesn't exist in Poser11, hence @seachnasaigh's trick with the construct, a Cycles node and the "Holdout" node.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
NikKelly ( ) posted Thu, 02 June 2022 at 5:34 AM
"If rendering in Superfly, you need to apply a holdout node to the construct."
Thank you, seachnasaigh, for providing a 'finder' map: Much appreciated.
Cybertenko ( ) posted Sat, 13 August 2022 at 5:17 AM
in firefly it still renders slight fringe around everything if saved as png. any chanve to get rid of it?
RedPhantom ( ) posted Sat, 13 August 2022 at 7:24 AM
Site Admin
What would do is match the background color to whatever was in the foreground, then the edges blended. It only works if there isn't much color change with the edges.
TwiztidKidd ( ) posted Sat, 13 August 2022 at 11:09 AM
Cybertenko posted at 5:17 AM Sat, 13 August 2022 - #4442708
I got a perfect render without the fringe around the fine hairs once, I knew how to do it, but I forgot LOL! I think I used a blank PNG as background or as a backwall prop or both. If I remember exactly I'll post the steps. I've included a blank 2400 x 2400 PNG
TwiztidKidd ( ) posted Sat, 13 August 2022 at 11:11 AM
LOL! that big blank space, right-click on it and save it, then import it as background.
TwiztidKidd ( ) posted Sat, 13 August 2022 at 11:15 AM · edited Sat, 13 August 2022 at 11:18 AM
If you find the blank PNG useful say: "Thanks for nothing, Twiz!" 😄
... and don't say I never gave you anything, yeah lol
Miss B ( ) posted Sat, 13 August 2022 at 11:17 AM · edited Sat, 13 August 2022 at 11:20 AM
OK folks, I guess I got really lucky when I first got my Poser 11 Pro, as it didn't (for some reason) have the Construct set up in the default Startup Scene.  I know another person who also found the same thing when she obtained Poser 11 Pro around the same time I did.
That said, however, it didn't take me long to find out how I could accomplish the same thing if my version had come with the "Alternate Construct" set up by default.  If you go to the Scenes Library, there's a folder titled Poser 11 Environments, and in that folder are 3 options.  1) Alternate Construct, 2) Developers Workspace, and 3) Poser 10 Workspace, which is the old P10/PP2014 "Ground Plane".  That gave me an option to go back to the old Ground Plane if that's what I wanted/needed.
It's easy to do, just select the Poser 10 Workspace, and save it as a new Startup Scene, making sure you've set it as Preferred Scene in the General Preferences Launch Behavior section on the Document tab, AND that Launch Behavior on the Interface tab is set to Launch to previous state, which will make sure every time you start a new scene you will get the new Startup file.
I set this up in Poser 12 as well, as the Scenes folder includes Poser 11 Environments, which includes the old Poser 10 Workspace option.  Just be sure to set up the Preferences as I mentioned above.  Now the only thing I need to remember is to click the Transparent Background on the Render settings when I'm working in Poser 12.
Needless to say, you need to "hide" the Ground Plane in the Heirarchy Editor.
Hope this helps.
_______________
Butterfly Dezignz
hborre ( ) posted Sat, 13 August 2022 at 1:42 PM
After hiding the construct, you can set the background color to black by clicking on the second dot from the left to open the color picker  xm579pGWUwABVEO3JcebBV0hLXAEPQ203K7LjX5v.png.
As Miss B posted, the renderer must be set for Transparent Background rendering, otherwise, the exported PNG will still exhibit a colored background.
Miss B ( ) posted Sat, 13 August 2022 at 10:33 PM
hborre posted at 1:42 PM Sat, 13 August 2022 - #4442719
Wow, after all these years using Poser I never knew what those dots were for.  ~makes a note~
_______________
Butterfly Dezignz
FVerbaas ( ) posted Thu, 18 August 2022 at 4:42 PM
Forum Coordinator
If you want the light effect the construct has ( that's what it is for) but render over transparent background you can put the Construct 'visible in Camera' off.  It is in the properties panel.
Rhia474 ( ) posted Sun, 25 June 2023 at 1:31 PM · edited Sun, 25 June 2023 at 1:31 PM
Well, sorry to resurrect this thread. It's Poser 13 time and I am trying ALL the methods above and none seems to work. Can someone share what they do if the following conditions are met:
I have a scene with the correct, carefully set up lighting that results in a great render. I want to do a PNG render with transparent background so just the figure renders BUT it has the exact lighting as I set up with the figure's environment for using in Photoshop later. How do you do that in Poser 13 please?
TwiztidKidd ( ) posted Sun, 25 June 2023 at 2:19 PM · edited Sun, 25 June 2023 at 2:21 PM
Are you using a HDRI bg photo with a dome for lighting? That's probably one of the many reasons.
If you could upload the PNG here it would help a lot too.
Rhia474 ( ) posted Sun, 25 June 2023 at 3:01 PM · edited Sun, 25 June 2023 at 3:01 PM
Sure, here:
As to what I used: AfroditeOhki's Level Up Superfly props: dome and background first. Then I removed the background and only used the dome. Then I added the Construct as suggested here and used holdout node on it.
In all cases I checked 'render over transparent background'. None of those brought the result I wanted ie. just the figure over transparent background.
I render very specific moods for both portrait and multiple-prop/figure scenes--how lighting looks is important to me. If that is not what I can do and I have to fiddle for hours in Photoshop to achieve the same, I better know it now.
hborre ( ) posted Sun, 25 June 2023 at 5:27 PM
Have you unchecked 'Visible in Camera' on the Properties tab?  All lighting is retained but the camera will not see the object or dome.
hborre ( ) posted Sun, 25 June 2023 at 5:56 PM
@Rhia, I am trying to understand your exact set up.  When you refer to the background, do you mean the Background material found in the Material Room?
Rhia474 ( ) posted Sun, 25 June 2023 at 6:15 PM · edited Sun, 25 June 2023 at 6:16 PM
@hborre: no, I mean the background prop that came with AO's kit. Hold on, let me get a screenie, had Poser closed atm.
Also: so--basically I did what you said and unchecked the 'visible in camera' for those two (backdrop and sphere) rendered with 'render over transparent background' checked and that gave me what I wanted.
THANNK YOU!
Now why is this not explained anywhere I ask? I have been using Poser since 2008, and this changes like every time Poser comes out?
hborre ( ) posted Sun, 25 June 2023 at 6:45 PM · edited Sun, 25 June 2023 at 6:46 PM
Okay, that clarifies everything.  I don't have Ohki's props that's why the confusion.  I'm glad my suggestion worked for you.  This was something I worked with some time back, making emissive objects invisible in the scene but still illuminating the surroundings. It also works with the actual Poser background.
TwiztidKidd ( ) posted Sun, 25 June 2023 at 9:39 PM · edited Sun, 25 June 2023 at 9:41 PM
Glad you figured it out. The reason I asked to see the PNG is bc some image viewers will show extra stuff... artifacts, on the screen around the figure but the PNG figure IS indeed transparent.
Best to load and view it in PS against the checkered background.
Thalek ( ) posted Wed, 28 June 2023 at 11:51 PM · edited Wed, 28 June 2023 at 11:51 PM
My previous effort at posting doesn't seem to have taken, for some reason.  At any rate, I couldn't remember how to create a Poser image with an alpha channel but fortunately, Google remembered this thread for me.  Now I have to learn GiMP's scripting language so I can automate creating an animation. Doing it by hand for 300 frames would be tedious.eR6VtPyuPPnuhKxnHbhGjDf3oH4WnOLVaOfBM1bB.pngfPYRBkuCvKR9fRbBsx6Xx7YkLMtECjwgaBwpjWyt.pngol
Plazagaai ( ) posted Thu, 28 November 2024 at 11:20 AM
Unfortunate you cant chose the background color where the alpha channel should render towards in Poser13 latest version. So if i chose for a white background color and render as transperant image for usage on light backgrounds i see black fringes because Poser forces a black background.
There should be a way to make those choices.
