Thu, Nov 28, 10:22 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Disapearing Runtime
Slowhands ( ) posted Thu, 17 March 2016 at 2:04 PM · edited Thu, 28 November 2024 at 10:17 PM
Out of the Blue, My Runtime disapeared. Now no matter what I do to open my Runtime I get this message. This Page can't, be displayed - Make sure the web address http://127.0.01:11530 is correct. Look for the page with your search engine. Refresh the page in a few minutes.
I copied and pasted that message below and this is what came out. I never had anything like this in 18 yeares I've been using Poser??? I don't even know that the message means.
Main Camera 0 focal Spline 50.0000 12 Main Camera 0 Perspective Spline 50.0000 93 Main Camera 0 focusDistance Spline 2.0000 105 Main Camera 0 fStop Spline 2.8000 106 Main Camera 0 shutterOpen Spline 0.0000 107 Main Camera 0 shutterClose Spline 0.5000 108 Main Camera 0 apertureRatio Spline 1.0000 122 Main Camera 0 apertureBlades Spline 0.0000 123 Main Camera 0 apertureBladesRotation Spline 0.0000 124 Main Camera 0 hither Linear 0.0930 14 Main Camera 0 yon Linear 100.0000 15 Main Camera 0 dollyZ Spline 1.7415 6 Main Camera 0 dollyY Spline 0.4247 5 Main Camera 0 dollyX Spline 0.0319 4 Main Camera 0 zScale Spline 1.0000 9 Main Camera 0 yScale Spline 1.0000 8 Main Camera 0 xScale Spline 1.0000 7 Main Camera 0 scale Spline 1.0000 10 Main Camera 0 roll Spline 0.3034 3 Main Camera 0 pitch Spline -4.0038 1 Main Camera 0 yaw Spline -2.0134 2
TrekkieGrrrl ( ) posted Fri, 13 May 2016 at 1:03 PM · edited Fri, 13 May 2016 at 1:03 PM
Did you ever get it solved? It's probably due to your firewall blocking it. It does that, sometimes :) Just allow Poser thru your firewall.
Slowhands ( ) posted Fri, 13 May 2016 at 2:32 PM
I'm sorry it took so long to get back, but it was due to Windows exployer, or the Internet exployer. I seen a reply that said that was their problem. I took it into my computer tech guy and which ever it was they fixed it. What a relief that was. But I told them to look into that if that happens again. Thanks
3Dpixi ( ) posted Sun, 22 May 2016 at 6:11 AM
Poser does interact with Adobe Flashplayer .. So with issues like these Update flashplayer > Restart pc > Problem solved
Slowhands ( ) posted Mon, 23 May 2016 at 10:15 AM
I have all the Adobe Cloud Products that relate to do everything I need, So my stuff gets updated everytime there is an update needed.
3Dpixi ( ) posted Mon, 23 May 2016 at 5:28 PM
Well .. it's a very common thing and well known solution .. actualy I had myself today .. updated my flashplayer and all back to normal .. so just a little tip and can't hurt to give it a try .. but of course that's up to you 🙂
Slowhands ( ) posted Tue, 24 May 2016 at 4:56 PM
Well my Flashplayer stays updated, but, that will help someone else if they read this. I at first was thinking that the problem was Poser how they check up to see if you are an actual owner of Poser. (how ever that is done) My bad! Poser is for me The best for easy animation. It is easy, but yet sophisticated. I do animations, and the Morphing Tool is a must have to save time in correcting poke throughs. I smooth skin when a body part bends and correct an undersired bulge. I use the smoot tool within the Morthing tool. I find it improved over older tools. Thanks Poser !
