Mon, Jan 20, 11:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: M.O.M Crowd generator grey outline?
timewyrm ( ) posted Sat, 16 July 2016 at 6:17 PM ยท edited Sat, 11 January 2025 at 9:30 PM
Im using the M.O.M crowd generator from Powerage - does anyone one know how to get rid of the fuzzy grey outline that appears around each "figure" when they are against a dark background?
Boni ( ) posted Sun, 17 July 2016 at 8:15 AM
Check your transparency settings in the mat room. Different render engines handle edges slightly differently.
Boni
Nails60 ( ) posted Sun, 17 July 2016 at 9:04 AM
The documentation with it says set your render options to the highest level. Being a novice I simply went to automatic settings and set it to the far right, past where it says final render. It seemed to work see attached render (As I was using terradome2 for this I had gamma correction off) p5ep1.jpg
Boni ( ) posted Sun, 17 July 2016 at 9:15 AM
Bravo! Glad that worked for you!
Boni
