Sat, Jan 25, 11:15 AM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2025 Jan 21 6:46 am)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Very important question..accually 3! PLEASE AWNSER!
randmanq ( ) posted Wed, 10 October 2001 at 5:01 PM · edited Thu, 08 August 2024 at 4:15 PM
  1. When I animate with a prop (all questions are to do with Poser4) these green lines come up. I do the rendering thingy and it goes away. I save my video and the green line is in the video!! How do I fix this?! 2. How do I import a bmp or JPG file and turn it into 3d? 3.When I animate.....say skateboarding...when I move a body part in one frame...that same body part goes all screwy in all the other frames. Same with props. How do I fix this?!? THANKS A MILLION!!!
MaterialForge ( ) posted Wed, 10 October 2001 at 8:33 PM
I can answer #1: Double-click the prop and uncheck the box that says "Display Origin" That should make the green lines go away. The green lines you're seeing are the object's center point. Hope this helps! --silver
DragoNegro ( ) posted Thu, 11 October 2001 at 7:12 AM
Ans. #2------a bmp or jpg is a 2d file, so it cannot be made a 3d object. If you use it as a map or decal, it can "look" like a 3d object. Ans. #3------check to see if you have the IK for legs or arms checked. depending on the type of animation you are doing, you may want to uncheck these.
randmanq ( ) posted Thu, 11 October 2001 at 4:37 PM
were can I go to uncheck the Iks?
DragoNegro ( ) posted Fri, 12 October 2001 at 7:31 AM
I don't work in Poser a lot, but I think that it is under the Figure menu
