Thu, Jan 23, 1:49 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 19 8:07 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: importing with texture from Daz studio.
exxe ( ) posted Sat, 13 August 2016 at 10:17 AM · edited Mon, 20 January 2025 at 9:26 PM
how do we import from daz studio with texture?
TheBryster ( ) posted Sat, 13 August 2016 at 10:54 AM · edited Sat, 13 August 2016 at 10:56 AM
Can anyone help out here? 😄
LuxXeon ( ) posted Sat, 13 August 2016 at 1:48 PM
If you export as OBJ, there's a few settings you will need to be sure you have set. Choose OBJ, then select Blender preset in the Convert To parameter. Enable Show Individual Settings, and make sure Write Surfaces is checked, and also Write Material Library. You will also want to check "Collect Maps". This will make copies of the maps and put them into a maps folder in the same directory as your OBJ. Now when you open the OBJ in Blender, it should find most of the textures that were capable of being saved. However, you may need to manually add some on your own. This will be simplified now, because you have collected them all in the maps folder in one location.
Another option is to export from DS as and FBX file. This has the option to embed the textures or collect them to a folder in the options. FBX is a little more reliable when importing objects with textures into other packages, but there's more settings to be aware of. FBX can also export rigging, lights, cameras, etc. So if you don't want all that, you might be better off using OBJ.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
maxxxmodelz ( ) posted Sat, 13 August 2016 at 2:54 PM
Not to complain about it, but the exporter in daz studio is less than perfect. I mean, it has all the options you would expect, but the way it formats the obj text is a little sloppy. Poser is even worse, but at least in my experience opening the obj in Blender will bring in diffuse, bump, and specular just fine. It won't import normal maps or some others, so you might have to connect those yourself. Also, the parameter values of the maps won't be the same, so there is a need to tweek the materials to get the look you need.
Mythic3D ( ) posted Sun, 14 August 2016 at 7:27 AM · edited Sun, 14 August 2016 at 7:29 AM
See also my response in this thread: https://www.renderosity.com/mod/forumpro/?thread_id=2905031 re: mCasual's DS and Blender scripts for doing this. Works with multiple items at once (although it choked when I tried it with a Stonemason set 😀) and sets up very basic Cycles shaders for you (with diffuse, glossy, bump and transparency only - any extra maps you need to set up yourself).
exxe ( ) posted Sun, 14 August 2016 at 11:36 AM
thank you all for the response!
