The latest as far as I know.I downloaded and installed it over the weekend. Cheers
Custom built computer 128 gigs RAM,2 Terrabyte hard drive, NVIDIA RTX 3060 12 Gig, Intel i9, Dual Dell Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terrabyte SSD Hard Drive plus 1 Terrabyte Hard Drive,3rd Computer intel i7,64 gigs ram, Graphics Card NVIDIA GeForce GeForce 1660 Ti 6 Gig,1 Terrabyte Hard Drive, OS Windows 10 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus Lenovo Laptop 64 Bit,12 gigs Ram.Intel i7 chip.Windows 10 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.22, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Mis-read your post!!! I believe EZskin Plug-ins At the SmithMricro forums. I reminded the guys of your question there. Hopefully someone will answer, especially since snarly goes there so much.
Chhers.
Boni
Yes, the soap, mud, wet skin for superfly/cycles is a plugin for ezskin 3. You must install it to have use of these functions. Once installed, you must select EZ_CycleSkin (SF) from the shader engine list. The options for the foamy, mud, etc are in the configuration for the shader engine once you have selected it. Here's a screenshot of what should look like.
Also note that the effects will only show up under superfly/cycles. They will not show in a firefly render as they are for superfly/cycles only.
Consider me insane if you wish, but is your reality any better?
Many Many thanks everyone. Cheers
One more question.Where do I get the plugin for Soapy,dirt,mud etc? Cheers
I must still be doing something wrong.I cannot get the cycles to open with the wet,soapy,muddy options.I have downloaded and installed the latest EZSkin 3 and cycles from CG.What am I doing wrong? Cheers
All good.I worked it out.Upon reading the instructions more closely I found that the cycles script must go in custom shaders. "Pays to always read the instructions".Cheers
If you haven't found it yet, it's due to being in the wrong configuration. From your screenshot, it looks like you looking in the "edit skin" configuration. The mud, etc, are in the configuration for the shader engine, the Cfg button, when you have selected the EZ_CycleSkin (SF).
The all in yellow area from my screenshot.
I posted this over at the Smith Micro Forum but nobody has replied.I have installed the new cycles script into EZSkin 3 and it works OK. however there are dirt,mud and soapy renders being shown.Is this separate script or something else? Cheers
